[QUOTE/]you cant use a wheel cleaning chemical that cleans brake dust, once you use that you can say goodby to any zinc coating you have..
Originally Posted by Dr.Dan
Since it was only months since this began to happen, I wonder if the Dealerships used a brake dust cleaner on them. The car was drop shipped to LPE, so it may have been my local dealer, while prepping the car, that did it. But it is almost 2 years later and getting them to admit might seem to be impossible.
Merry Christmas to you too, ET
I could almost bet that 90% of dealerships have never heard of zinc coated rotors.. Ive seen several post over the last few years about dealers washing cars with zinc coated rotors and ruining them.. the few people that have posted this said, they (deralership ) was not notified of any issues the rotors .. and it was the policy of the dealership to return the customers car with a washing. These chemicals are ok for clear coated wheels. So with that in mind , zinc has to me more delicate than clear coat... thats why I think my method is good.
Another tip is dont bite off more than you can chew..
One or two rotors in a day is about all you should do..
if you try to do them all... by the forth rotor you will give it about 50% of the effort of the first rotor.
Same thing if you try to do the insulation mod... it takes several days to do it right..
Today while cruising the forum I found a thread that referenced a member who bought new Wheels and was showing them off with a few pictures,.. the car was beautiful, the wheels where beautiful, and very expensive.. I cant for the life of me see someone investing 7 grand on wheels, then taking the time to photograph them, With completely rusty rotors, I mean Super rust completely covering them, and with dirty wheel wells. Now these wheels are brand new, so he had to take the old ones off . Is it me, am I that ****? If you buy beuatiful wheels, that draw your attention to them.. shouldnt the whole area be clean?? to me rusty rotors and dirty wheel wells and 7 grand for wheels is a completle waste of 7 grand.
How do some folks at shows keep their brake rotors so shiny. Have been thinking of doing something to spruce them up over the winter, but have no idea WHAT to do...
History:
The zinc wash on my Eradispeeds are definitely NOT up to snuff. Called Baer and they basically said "oh well, this happens and the coating is there only to retard the rusting. Anything cast iron will rust." The area where the calipers don't grab (about 1-1/2" on the +1s) were rusting in the first year. I painted that area and it's holding OK, but not great. Even the holes and slots show some rust. Great stopping ability...Crappy in the looks dept.
Dan
Mine started rusting in the holes and insides after 1000 miles. Now after approx. 6G they look atrocious. If I keep the car they are getting replaced next spring.
Think I have a line on a plater to re zinc coat them. They were busy today and asked me to call back next week for the particulars. Only took 7 phone calls.
Dan, I'd appreciate it if you could post the info when you get it straightened out. I went back and read all the posts here, this is an awesome thread!!!
Now instead of looking for new rotors I am ready to get to work on mine. Having them re-coated then following ET's advice sounds like the way to go.
A few people have told me to just drive it and the rust will be wiped away. Not so with the +1's as there is an inch or so out of the firepath.
JL,
Will keep you posted. I don't yet have the rotors off the car so I cannot give first hand info, but will post what I have.
Dan
Thanks Dan. I'm thinking about messing around with my fronts this weekend, though I am reluctant to pull them as I haven't been able to find the high heat clear locally.
Something I've been thinking about though, can 2 piece rotors such as we have be re-plated? I'll admit that I don't know anything about this.
Just glad it was posted here and not on the Tires & Wheel Section since I seldom go there.
ET, would your procedure work with the calipers removed and the rotors left on the wheel? I've had my calipers off before but I'm not too eager to do that last step before the clean-up. Thanks for all your continuing contributions to this great forum. BTW..... could you post a link to your rear wheel well insulation write up? Merry Christmas to all,
I have used spray brake cleaner on my zinc plated rotars. hhhhhhmmmmmmm sounds like I have trashed the zinc coating. I know, they look NOTHING like ET's. Heck they didn't look like that when they were new.
Now that the Zinc coating is gone (my fault) can the roatrs be polished and sprayed with 1500 clear coat?
Check this beauty out. I have a hard time believing that this POS can be resurrected, no matter how much time I put into it. The right rear actually looks worse than my fronts.
I have used wheel cleaner many, many times. My questions would be if these rotors are so sensitive to these type of chemicals, then why don't the manufacturers of the rotors mention this? Baer doen't mention this anywhere in any of their installation instructions.
From: Biloxi MS Theres something happenin' here, What it is ain't exactly clear.....
Originally Posted by vetteconvert
Cadium has been used on brake rotors forever. It usually adds something like $15-$20 to a rotor's price.
Cadmium:
Exceptional white luster similar to silver plating
Corrosion resistance in marine environment
Excellent Lubricity
Low electrical contact resistance
Uniform ductile deposit
Pliant
Solid Rust Prevention
Can be solder almost as well as tin
Carbon-Ceramic rotors are the rotors used on Porsche GT and high-end Ferrari's. They have no iron in them to rust and along with the pads create almost no dust. But, they cost around $5000 EACH!
Well I am going to post pictures of my Rotors tomarrow. But I did clean them today with Green Gunk (PepBoys)....I figured this is safe. I was suprized to see that my fronts actually showed signs of rust (I think) on the very edges. The holes and slots looked rusted also but I think its actually the ceramic material from pads burnt into the rotor beccause on my rears it is still silvery looking outside of the pad fire path. This will be easier to see when I post the pics.
I did throw away a bottle of Armoral Wheel Cleaner after reading the fine print that said not to use on ZINK!!! I went to Pep Boys and spent an hour reading the labels/fine print on every single wheel cleaner product. They ALL claim to remove brake dust. Only one...HOT Wheel Cleaner from Maguires said not to use on brake parts. Most had acids (sulfuric and hydrochloric) as ingredients. I found two that specifically said "Contain No Acid"....one by Turtle Wax the other by Simonize. I bought the one by Simonize cause in said it was also safe on Rubber!!..figuring it had to be the most gentle.
Anyways I don't know how any of these products expect you to clean your wheel without getting the **** on your rotors/pads unless you take the wheels off the car.....and non of them mention this. I am also pissed that Baer doesn't warn of this issue.....they are going to hear from me on Monday.
My rotors never had a chrome/mirror finish...just a dull silver(zink?) finnish.
Mike....we gotta find our own local AnalRetentive (Evil) to help with this issue. I get a hardon everytime Evil posts pics of his rotors.
Holy $***
Mine are nowhere that...uh...interesting. Maybe I'm just being almost as **** as ET, that is without the cool looking rotors.
I was thinking the same thing. Think that a call back to Baer is in order on Monday. Think that it would be better to take the rotor apart before replating. They'd probably freak. They should warn folks not to use harsh cleaners on these delicate rotor surfaces
They don't tell people cause they want them to keep coming back for new rotors. I actually keep my car looking like brand new (only 15G miles), I even have a hot water hose hook up in my garage for winter cleaning.
These rotors just never held up. Definitely the most disappointing purchase for my C5. Like I posted, they were starting to look rough after 1000 miles. I am going to replace these if I keep the car, but I don't know if I will spend the money on Eradispeed's again.
