So who has replaced this? My LF turn signal went out, pulled the bulb and it was bad. Changed the bulb and still does not work. The DRL and hazards still work just no LF turn signal. I pulled out my shop manual and it says the turn signal flasher is integrated into the hazard warning switch. It does not look like it will be too hard to do I'm just looking for advice from anyone who has done it before.
Does anyone know the part number for the hazard/turn signal switch so I can order one and have it on hand?
ya I got that part, it doesn't look to bad to pull the dash pad
Hmmm.. O.k., if you say so!
Several members (including GM techs) have successfully swapped them via removing the radio to gain access to the back of the switch, w/o removing the dash.
If you are capable of removing the dash, you won't need any further instructions on replacing the switch.
