Oil filter...
Old Dec 22, 2004 | 04:55 PM
RandyC5's Avatar
RandyC5
Default Oil filter...
Does it really make a difference if i fill the filter with oil prior to instalation or will everything be fine if i just don't worry about it
Thanx
Old Dec 22, 2004 | 05:02 PM
Jackal's Avatar
Jackal
I dont know what difference it really makes, especially since it is so small. However, I ALWAYS pre fill my oil filters...it is better to be safe than sorry.
Old Dec 22, 2004 | 05:03 PM
screw991le's Avatar
screw991le
From: Redsox, Pats, Celts & Bruins !!! Redsox Nation !!!
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
Primes the system, can't hurt, prevents "dry start"
Old Dec 22, 2004 | 05:47 PM
jrose7004's Avatar
jrose7004
I always fill mine! I figure that its somehow better!
Old Dec 22, 2004 | 06:28 PM
Mikelly's Avatar
Mikelly
In filling the filter before you install it, you insure that the pickup tube has oil in the system quicker than if you did not fill it. It is MUCH better than not doing it and hearing tapping noises from a dry system after the change.
Mike
Old Dec 22, 2004 | 06:52 PM
vettenuts's Avatar
vettenuts
I always do it too, especially on the GM cars where the filter is upside down and the oil stays in. Its a little messier on some of my other cars
Old Dec 23, 2004 | 10:52 AM
JC in XTC5's Avatar
JC in XTC5
It's easy on this car, and it minimizes the delay getting oil through the system on the first start.
Old Dec 23, 2004 | 01:40 PM
16Again's Avatar
16Again
St. Jude Donor '07-'12, '20
I'm just programmed over the years to fill the filter. Always was told never start a car with no oil. No oil in the filter, means no oil in the motor.
Bob
Old Dec 23, 2004 | 01:43 PM
Ikester's Avatar
Ikester
CI 6-7-8-9 Veteran
St. Jude Donor '08-'09
George V's Avatar
George V
Fill the filter it only takes a minute. I have a few cars in the family that I cant pre-fill and it drives me nuts to run them dry.
Old Dec 23, 2004 | 02:33 PM
Wolfmanjohn's Avatar
Wolfmanjohn
I agree with all of the above; fill that filter whenever possible!
Happy and safe holidays!
Old Dec 23, 2004 | 03:00 PM
Bruceatlam's Avatar
Bruceatlam
I've never worried about "priming the filter" on an oil change in any car that I've owned.
I have "primed" new engines on "first start" -- I subscribe to that as a good idea.
My "bias" is to the 3,000 mile oil change frequency regardless of what any manufacturer might say ---- never had an engine lubrication problem in close to 40 years worth of oil changes on a wide variety of vehicles.
Old Dec 23, 2004 | 03:10 PM
C66 Racing's Avatar
C66 Racing
Premium Supporting Vendor
I'd ask, why not? It certainly isn't going to hurt and only takes about 15 seconds...
__________________
C66 Racing #66 NASA ST2, SCCA T2
AMSOIL Dealer (Forum Vendor)
AMSOIL Preferred Customer Program (Members buy at Wholesale - a savings of about 25%)
Old Dec 23, 2004 | 04:08 PM
Bruceatlam's Avatar
Bruceatlam
And I can't argue with that. I just don't think it's critical.
Old Dec 23, 2004 | 10:33 PM
TrueBlueCoupe's Avatar
TrueBlueCoupe
I always fill my filters! I have been changing my own oil and doing this for 20 yrs.
Old Dec 23, 2004 | 10:42 PM
whitelite's Avatar
whitelite
Doesn't this assume that the oil is picked up out of the filter by the oil pump? I think the pickup is in the oil pan, so it shouldn't matter...IMHO
Old Dec 24, 2004 | 01:24 PM
w8d4it's Avatar
w8d4it
St. Jude Donor '04-'05-'06-'07-'08-'09
I used to prime and then suddenly the light of this logic hit me about 15years ago. So I don't anymore. Haven't had a problem in the 15 years since I stopped and didn't have a problem in the 20 years before I stopped. So I don't think it makes any difference.
Old Dec 24, 2004 | 02:12 PM
C66 Racing's Avatar
C66 Racing
The pickup is in the pan, but the oil flows through the filter then to the engine so if the filter is full of air it would seem to me that the air is going to flow through the engine, bearings etc before the oil does.
This effect is probably minimal though...
To Oil filter...
