Upgraded diff clutch packs
Old Dec 23, 2004 | 09:42 AM
C5JONNY's Avatar
C5JONNY
Default Upgraded diff clutch packs
Im going to have my rear apart to install hardened output shaft. Is there any type of upgraded clutch pack assembly for these. Just trying to cover everything in one shot. Im not pushing major HP but I figure since it will be open.
Old Dec 23, 2004 | 09:44 AM
16Again's Avatar
16Again
St. Jude Donor '07-'12, '20
Yes, DTE has a new heavy duty version out. Just give them a call, inexpensive as well.
Bob
Old Dec 23, 2004 | 09:45 AM
C5JONNY's Avatar
C5JONNY
Nice, thank you
Old Dec 23, 2004 | 09:50 AM
16Again's Avatar
16Again
Here is the link.......
http://forums.corvetteforum.com/show...&highlight=DTE
Old Dec 23, 2004 | 09:51 AM
vetteshop's Avatar
0vetteshop
Former Vendor
St. Jude Donor '13
Also see if an upgraded beville washer comes with the clutch packs.It is common for these to break
Old Dec 23, 2004 | 10:32 AM
DTE Powertrain's Avatar
DTE Powertrain
Collections Hold
We do have a HD Getrag differential clutck pack available as well as HD clutch pack pre-load springs.
- DTE Clutch Pack Kit: $105.65/side
Two kits required for each differential
- DTE HD Clutch Pack Preload Spring Kit: $49.99/pair
One pair for each differential
-DTE HD Clutch Pack Combination Kit: $249.99
Includes all DTE friction discs, steel discs and preload spring set complete for both sides. We have everything in stock.
Merry Christmas!
DTE
Old Dec 23, 2004 | 10:37 AM
5 Liter Eater's Avatar
5 Liter Eater
St. Jude Donor '11
I may be wrong but I believe the DTE upgrade is simply a heavy duty belleville washer, not the entire clutch pack. The HD washer provides added pressure to the clutch packs which adds more clamping force which will provide less slip but the actual cluch packs are OEM.
Old Dec 23, 2004 | 11:09 AM
C5JONNY's Avatar
C5JONNY
Im not pushing major HP, but neither are two of my buddies whos diffs failed because of a badly prepped water box. I think I only need some extra clamping pressure. Ill be calling you guys later, thanks
Old Dec 23, 2004 | 01:56 PM
5 Liter Eater
St. Jude Donor '11
I would say that if you're taking your diff apart to install a hardened long shaft it would be worth another $50 for these DTE washers although it adds a little complexity to the job since the right side washer is behind the spider gears and requires compressing the existing washer to get them out.
To Upgraded diff clutch packs
