Hud
Old Dec 23, 2004 | 06:46 PM
scaperman's Avatar
scaperman
Default Hud
I have a 98 and want to put a hud in it is the wiring harness in the dash ? will there be any problems because i don't have that special windshield?
Old Dec 23, 2004 | 07:10 PM
98droptop's Avatar
98droptop
I have the same question, somebody out there will have the answers
Old Dec 23, 2004 | 07:14 PM
screw991le's Avatar
screw991le
From: Redsox, Pats, Celts & Bruins !!! Redsox Nation !!!
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
I think the windshield is required. It has a coating on it, from what I understand.
Old Dec 23, 2004 | 08:04 PM
Suprfun's Avatar
Suprfun
Just finished adding a HUD to my 97 coupe. If you have a 97, 98 and most of the 99 you will need to purchase the speedometer cluster along with the HUD assembly. There is a wiring harness that runs between the two. No additional wiring is needed. If you do a search on adding a hud or look in: https://www.corvetteforum.com/techti....php?TopicID=1
under "Installing a HUD" you'll find alot more information. I bought everything needed from Gene's Karshop, great guy to deal with! BTW mine shows up just fine with the standard windshield.
Happy Holidays!
Old Dec 23, 2004 | 08:37 PM
RPOZ4Z's Avatar
RPOZ4Z
Cruise-In VII Veteran
No need for the HUD windshield!
Old Dec 24, 2004 | 10:09 AM
scaperman's Avatar
scaperman
Thanks for the info guys
Old Dec 24, 2004 | 10:13 AM
BiggieBoy's Avatar
BiggieBoy
Installed a HUD in my '98 last summer. No need to install HUD windshield. The non-HUD windshield works fine. Good luck w/ your project----It's really a add on.
Old Dec 25, 2004 | 01:07 AM
SpeedyZ's Avatar
SpeedyZ
I just installed a HUD in my 2001 Z06. The image looks as good as any factor installed HUD that i have seen.
To Hud
