B&M Ripper or Hurst?
Old Dec 25, 2004 | 03:21 PM
Casem1's Avatar
Casem1
Default B&M Ripper or Hurst?
OK, I got a Ripper for Xmas, but the order was screwed up and it was supposed to be a Hurst. I can still get the Hurst, but should I bother?
Has anyone had both of them? i know a Hurst is prone to rattling, but also it is adjustable... What are your thoughts???
Old Dec 25, 2004 | 03:43 PM
Cunningham Motorsports's Avatar
0Cunningham Motorsports
Former Vendor
i drove a vette with a ripper and i liked it alot, never driven one with a hurst, but i have a breathless myself i like it alot very adjustable and shortest throws, but i believe its the stiffest
Old Dec 25, 2004 | 04:14 PM
HIGHRPM's Avatar
HIGHRPM
I tried all the after market shifters.... the Hurst is on my car. The Ripper is too stiff and requires way more effort to make quick shifts.
Old Dec 25, 2004 | 06:08 PM
w8d4it's Avatar
w8d4it
St. Jude Donor '04-'05-'06-'07-'08-'09
Exactly the opposite experience for me. I had a Hurst and it was way too stiff. I went to a Ripper. Liked it a much better. Then shortened it about an inch and a half and like it even better.
Old Dec 25, 2004 | 07:37 PM
Rob'sC5's Avatar
Rob'sC5
Cruise-In V Veteran
St. Jude's Donor '05
I had a F Body that had a Hurst in it. Now I have a Ripper and I think I like it better. Its a smoother shift between 1st & 2nd and 3rd & 4th. The Husrt was alittel noisier but I jsut turned the stereo up
Old Dec 25, 2004 | 08:03 PM
Z06-JIM's Avatar
Z06-JIM
Cruise-In VII Veteran
Never tried the Hurst but really like the Ripper in my car!
Old Dec 25, 2004 | 08:27 PM
K.Shupe's Avatar
K.Shupe
St. Jude Contributor
I've owned the Ripper and the Hurst, both are first class well built shifters. I drove the Ripper for about 3 years in my y2k, then decided to try the Hurst when I got my 03. I've now driven the Hurst for about 2 years. My impression is that the Ripper and the Hurst have a very similar feel when the Hurst is equipped with the default springs. If I were to pick one, I would give the nod to the Hurst because of it's adjustability. Shifter feel is a very personnel thing, like women, everyone likes something different soooo the ability to change springs in the Hurst should allow you to find something you like.
Old Dec 25, 2004 | 11:24 PM
MarvinsCart's Avatar
MarvinsCart
I have a hurst and i am completely satisfied. It should be the first mod you do to your corvette
Old Dec 25, 2004 | 11:51 PM
screw991le's Avatar
screw991le
From: Redsox, Pats, Celts & Bruins !!! Redsox Nation !!!
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
I also had a hurst comp + in my f-body and would get it again.
Old Dec 26, 2004 | 01:35 AM
Ikester's Avatar
Ikester
CI 6-7-8-9 Veteran
St. Jude Donor '08-'09
Get hurst, no rattles here! Just have to deaden the sounf with Teflon tape on the **** threads
Old Dec 26, 2004 | 01:49 AM
Perry Mason's Avatar
Perry Mason
I, too, have a ripper on my '04. I removed the stock shifter within 2 weeks of buying this new car. The stock shifter does remind me of rowing.
My Q: Did you remove the shifter to cut it? Did you add new threads?
Old Dec 26, 2004 | 02:00 AM
leaftye's Avatar
leaftye
Why not the Breathless? The Breathless has adjustable springs like the other shifters, but the inclination of their shifter can be adjusted as well. I've heard lots of good things about their shifter....their coilover kits and nonpopup headlights are a totally different matter.
Old Dec 26, 2004 | 06:30 AM
PHPD7102's Avatar
PHPD7102
St. Jude Donor '14-'15-'16
Ripper on mine, a little stiff the first couple hundered miles and took some practice to hit 3rd right, but now that I have it down its great. No rattles at all.
Old Dec 26, 2004 | 07:41 AM
Casem1's Avatar
Casem1
Thanks guys! leaftye I can't get the Breathless because this particular vendor only carries the B&M and Hurst, and as a gift only the exchange would be possible. I just can't believe they sent the wrong one. The almost sent it to Maine as well...
Old Dec 26, 2004 | 09:48 AM
AN1313's Avatar
AN1313
I have the Hurst in my car, but drove another with the Ripper. Both are much better the stock unit in my opinion.
I prefer the Hurst due to the adjustability and slightly easier gear engagement (i.e., less notchy).
A correct install is critical to having a good experience with your aftermarket shifter. Do a search and you will find plenty of information.
Old Dec 26, 2004 | 11:14 AM
Mikelly's Avatar
Mikelly
I have had the Ripper, the Hurst AND the KIrban unit all within the last year... They all rattle unless you do the cabscrew mod mentioned in the tech section, and I'd avoid setting the stops real close, since the M6 has its own internal stops.
The Kirban shifted the best of the aftermarket units, but they all blow compared to the Z06 Shifter I just installed.
Mike
Old Dec 26, 2004 | 12:28 PM
MarvinsCart
You know the Hurst does " Rattle " A little But it dont seem to be really bad until you get over 100mph. Now that i have the long tubes on and no cats with stingers Hearing a Rattle is nothing but a fond memory
To B&M Ripper or Hurst?
Old Dec 26, 2004 | 01:50 PM
AN1313's Avatar
AN1313
My Hurst does not rattle since I used Locktite during the install.
Old Dec 26, 2004 | 02:00 PM
Nate@CorvetteGarage's Avatar
Nate@CorvetteGarage
Supporting Vendor
Cruise-In I Veteran
St. Jude Contributor '04
I have tried and used all available shifters in my C5 and Z06's, and in my opinion, the B&M is the way to go.
In the beginning, years ago, the B&M was among the first available for the C5, but it was very stiff. The hurst was released later and was much easier to shift, so everyone praised it. Well, shortly after the Hurst was released, B&M revised the spring rate in their shifters (because of complaints), and now its the easiest to shift between the two. Shift shortness is the same. Noise is close to the same between the two, but B&M supplies an extra rubber boot that covers the base of the shifter. It does help slightly.
Again, these are only my opinions and thoughts.
Thanks,
Nate
__________________
Corvette Garage Inc
Xtreme Motorsports
1.806.863.3800
Website: Click here for Corvette Parts and Accessories!
Email: sales@corvettegarage.com
Old Dec 26, 2004 | 03:24 PM
AN1313's Avatar
AN1313
The Hurst definitely allows noise through the center opening of the stock rubber surround. I cut a circular piece of rubber and press fit it over the shaft to seal this opening. If the B&M seals this with an included rubber cover, that is a huge advantage in my opinion.
As far as stiffness, I used the softest spring in my Hurst and I think it is perfect.
