Hurst shifter install question
Old Dec 26, 2004 | 12:20 PM
gsxrjack's Avatar
gsxrjack
Default Hurst shifter install question
got my new hurst shifter for christmas for my 2000 coupe, got the stock one off and noticed a small pin on the foward side of the shifter, is this the reverse lockout pin ive heard about. and do i just take it off and leave it out...
also, the hurst shifter looks like it can go either way, like theres not a front or back to it, is this a true statement and can be assembled either way???
jack
Old Dec 26, 2004 | 12:25 PM
MarvinsCart's Avatar
MarvinsCart
I have a hurst and i installed it myself. I dont know anout your pin thing. I never remeber seeing a pin. The shifter will go both ways There is no front or back
Old Dec 26, 2004 | 02:09 PM
vettenuts's Avatar
vettenuts
The pin is for alignment of the shift linkage and is part of the stock shifter. You don't need to do anything with it, but don't drop it into the tunnel either. As for front and back, I don't remember.
Old Dec 26, 2004 | 02:28 PM
gsxrjack's Avatar
gsxrjack
is this the one, and do i just remove it...here are some pics of it
large pic
Old Dec 26, 2004 | 02:38 PM
HassounVETTE99's Avatar
HassounVETTE99
Cruising
Hey bud,
The pin is required only for the stock shifter. Just take it out and store it with your old shifter. As far as which way you install your shifter, you have to install it with the rectangular opening on the handle by the threads(for the lock for the shift handle) facing the back of the car not the front. I've installed too many shifters!!!
Old Dec 26, 2004 | 02:43 PM
gsxrjack's Avatar
gsxrjack
Originally Posted by HassounVETTE99
Hey bud,
thanks, i did figure i had to have the opening facing the back for shift ***** to go on correctly...thanks about the pin...off it goes
again thanks all for your help
Old Dec 26, 2004 | 02:49 PM
servohead's Avatar
servohead
Hey let us know how you like the shifter after the install! I got one for christmas too and I'm curious !
Old Dec 26, 2004 | 04:18 PM
Shylor's Avatar
Shylor
You can take out the rubberband from the OEM shifter also.
Old Dec 26, 2004 | 07:35 PM
gsxrjack's Avatar
gsxrjack
well its gonna be a while, its snowing like a baastard here now
Old Dec 26, 2004 | 08:09 PM
JUSAKD's Avatar
JUSAKD
Just done mine the other day. Can not believe the difference. The stock one really is a piece of crap. Can we say that on the forum. Sorry if not.
I have to learn to shift over again. When I go for 5th I keep pushing to reverse.
So short and precise. Gripper shift **** is nice too.
Old Dec 26, 2004 | 09:01 PM
Ikester's Avatar
Ikester
CI 6-7-8-9 Veteran
St. Jude Donor '08-'09
Dont forget, remove the adjustable stops on the hurst unit, you dont need them.
Old Dec 27, 2004 | 02:02 AM
Shylor's Avatar
Shylor
Unless you are going to be doing some slamming hard race shifts often. Then (even though the trans has internal stops), you will need the shifter stops to help prevent damage to the internal trans stops. But if you just do street driving with some racing, then I'd remove the shifter stops.
Old Dec 27, 2004 | 07:14 AM
Patches's Avatar
Patches
Here's a tutorial I did a while back.
http://temp.corvetteforum.net/c5/pat...rInstall.shtml
Old Dec 27, 2004 | 08:19 AM
CarsRFun's Avatar
CarsRFun
thats a damn good tutorial you made there!
I saved it for when I do mine!
Thanks!
Old Dec 27, 2004 | 08:35 AM
gsxrjack's Avatar
gsxrjack
i had printed out your tutorial and thats how i installed mine...just no mention of that pin...great job though...
Jack
Old Dec 27, 2004 | 05:00 PM
Shylor's Avatar
Shylor
Yes but the pin is shown with the OEM shifter out of the car. Giving you the clue that it does not go back in the car.
Old Dec 27, 2004 | 05:42 PM
gsxrjack's Avatar
gsxrjack
i saw that also, just wanted to be 100% sure...dont want to leave something out and have to tear into it again....
like i said, i printed out your pages and thats what i used to do the job...if you want my opinion, id just add to remove that pin and put it away to your great instructions...hell even the hurst instructions dont mention it and there pretty good also....
To Hurst shifter install question
