Need help swaping leaf spring
Old Dec 26, 2004 | 08:55 PM
corvettefrance's Avatar
corvettefrance
Default Need help swaping leaf spring
I already start to remove the front leaf spring to install the T1.
how can you remove the front leaf spring I already unbolt everything and this F...... spring does not want to come.
the four bolts underneath, the shocks botom bolts to free the botom.
where is the trick?
thanks
Old Dec 26, 2004 | 11:11 PM
Rex99Coupe's Avatar
Rex99Coupe
LS1Howto.com has complete instructions on this, the web site seems to be down at this time.
Good luck!
Old Dec 27, 2004 | 03:31 AM
MTV's Avatar
MTV
St. Jude Donor '03-'04-'05
Have you removed sway end link bolts from one side and the 4 upper A arm bolts from both sides?
The 'How To' described above is the best resourece. Good Luck!
mtv
Old Dec 27, 2004 | 11:49 AM
corvettefrance
yes LS1howto was down that why I wrote this threads.
I removed the sway bars shocks and you also have to remove the two bolts holding of the a arm
Old Dec 27, 2004 | 01:48 PM
97C5ENVY's Avatar
97C5ENVY
Here's a write-up I did a few years ago on how to swap out the springs (which Jon used for the basis for his write-up on LS1Howto.com): http://home.hot.rr.com/playtoy97c5/c...ng_Install.txt
Old Dec 27, 2004 | 11:04 PM
corvettefrance
Thank you guys
To Need help swaping leaf spring
