Running without HVAC control
Old Dec 27, 2004 | 01:40 PM
99C5Vert's Avatar
99C5Vert
St. Jude Donor '03-'11
Default Running without HVAC control
If the HVAC control (dual zone) is removed, does the car throw codes? Is any other system impacted?
If codes are thrown, can the feature be turned off?
I'm hoping some of you who use your car as a dedicated race car can answer this.
Old Dec 27, 2004 | 06:42 PM
juiced's Avatar
juiced
the car runs fine it will just throw the HVAC communication code. no big deal it's like pulling your radio out.
Old Dec 27, 2004 | 06:44 PM
99C5Vert's Avatar
99C5Vert
Is this an actual code on the DIC?
Removing my radio did not cause a code
Old Dec 28, 2004 | 01:07 AM
1 slow 97's Avatar
1 slow 97
the code will show up only if you go to the menu and scroll through the codes. it will not appear on the DIC when you turn the car on. IF you scroll through the codes and get to HVAC, you notice either a c for current or H for history. Likely the code with show the number and then a c next to it. But it wont affect anything. Email me if you would like to sell your AC controller as the light has burned out in mine and I need a new one. jaugerinos@aol.com
Old Dec 28, 2004 | 01:12 AM
99C5Vert's Avatar
99C5Vert
Cool. Thank you for the offer. Actually, I'm toying with the idea of replacing the unit. I've installed an in dash PC with various data acquisition and control stuff, and integrating the HVAC into the touchscreen gives me a little more room.
Something to work on i guess
To Running without HVAC control
