Squeeking sound when going over bumps
Old Dec 28, 2004 | 12:57 AM
sambarnett's Avatar
sambarnett
Default Squeeking sound when going over bumps
The sound just started recently and is is coming from the front. I think it might be only the front right. Whenever I go over a speed bump it does it or any time the car bounces up and down in the front. Any ideas?
Sam
Old Dec 28, 2004 | 07:27 AM
SEAMOORE's Avatar
SEAMOORE
Lube your sway bar rubber busings w/dielectric grease. Fixed mine last week.
Old Dec 28, 2004 | 12:11 PM
sweetcharity's Avatar
sweetcharity
St. Jude Donor '11-'12-'13, '15
That and also check the torque on the end links as well.
Old Dec 28, 2004 | 06:54 PM
bpc4me's Avatar
bpc4me
Old Dec 28, 2004 | 11:03 PM
alanh's Avatar
alanh
The squeek is from rubber suspension parts. It comes on with the colder weather and if you wait long enough, say until spring, it will probably go away and not come back until next winter. If you can't stand it, lube it.
Old Dec 29, 2004 | 01:08 AM
cmyc5's Avatar
cmyc5
Old Dec 29, 2004 | 10:24 AM
sambarnett's Avatar
sambarnett
What are the torque specs for the sway bar bushings etc. that I will need to unbolt to put the grease on?
Sam
Old Dec 29, 2004 | 05:07 PM
sweetcharity
Lower clamp bolt= 70 lb ft
Upper clamp bolt= 49 lb ft
link nuts= 53 lb ft
Old Dec 29, 2004 | 05:12 PM
screw991le's Avatar
screw991le
From: Redsox, Pats, Celts & Bruins !!! Redsox Nation !!!
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
Did the same thing a few months back, I used zep spray silicone.
I sprayed every rubber piece I could find and to this day no squeaks.
Old Dec 29, 2004 | 05:16 PM
spoiled996's Avatar
0spoiled996
Former Vendor
St. Jude Donor '12
i had a squeak last winter...had to have my bearing and hub assembly replaced...have a squeak this year...had to get a bracket replaced as it seems that one of 2 things happened. 1 i hit something or 2. when i went over a speed bump ( car is lowered ) that before my front left tire hit the speed bump the bump actually pushed on the front left bracket infront of the radiator and bent it and loosened the bolts attached to my frame front end...Car in shop for 3 days now...$320 later in parts...
but noise is fixed now!
To Squeeking sound when going over bumps
