Can Corsa Torque Clamps hold?
Old Dec 30, 2004 | 01:51 AM
Voide3's Avatar
Voide3
Default Can Corsa Torque Clamps hold?
After 4 hours of fiddling with the mufler alignment with some Corsa Touring muflers I got close enough to get by. I torque the clamps down to spec, and as best I can tell, they won't hold. The muflers still move around by hand some. I do not see how they are going to hold on the road. I know tack welding is an option.
2 questions:
1. Is there a trick to make the clamps hold better?
2. Does anyone know a good muffler shop to do the alignment and tack weld in central Arkansas? (Little Rock, Conway region).
Old Dec 30, 2004 | 02:02 AM
1FUNVTT's Avatar
1FUNVTT
Just installed my Corsa a week back. I too had that problem. I found if I torqued the clamp to the specified lbs, the clamps were too loose and wouldn't hold tightly. So I went ahead and tighten the clamps so they were tight (no movements of the mufflers) and torqued to spec then. So far no problems. I guess the main thing is not to overly tighten and crush the pipes. My thoughts .... for what's worth.
Old Dec 30, 2004 | 02:57 AM
vettecop1125's Avatar
vettecop1125
CI 7-8 Veteran
St. Jude Donor '03-'04-'05
One side of my Corsas always rotated up so I took it to Monro muffler and had them weld it in place. $20 and 9 months later, they haven't moved.
Old Dec 30, 2004 | 09:06 AM
tboneinsc's Avatar
tboneinsc
I agree the Corsa clamps will not hold. The right bank of my exhaust actually fell off twice before I had them welded in place. The Corvette shop that did the work for me said a lot of people have trouble with Corsa exhausts staying lined up right.
Old Dec 30, 2004 | 09:23 AM
Pumba's Avatar
Pumba
Frank,
Did you apply a good quality copper-based anti-seize compound to the threads of the clamps before you torqued them?
If not, I suggest that you start over. The anti-seize compound will allow you to apply more tension in the joint at the same torque.
Good luck wity your decision.
Old Dec 30, 2004 | 12:39 PM
Wolfmanjohn's Avatar
Wolfmanjohn
Greg,
Good to read that you went with the Corsas; hope the sound is what you were looking for.
The guys who did my install told me to run them around until they shifted, then bring them back in for realignment. So far (8 months), there has been none, so I think I'll take it in and have them tack it. Sounds like you took the right approach in your installation.
I'll be lookin' for ya around town; maybe we can do a little "dual Indy run" for the local populus and show 'em some GOOD sounds!
Safe and happy new year!
Old Dec 30, 2004 | 02:26 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
I purchased some VERY cool heavy duty stainless clamps for my Stainlesworks system. The clamps that came with the systen sucked and like you said would NOT hold very well. I will attach a digital photo of the clamp to this post when I get home from work!
Old Dec 30, 2004 | 08:20 PM
Fastguy's Avatar
Fastguy
St. Jude Donor '03-'05
I put the anti-seize and cranked the unholy hell out of them. Then one fell off, got jammed under a Mustang, and I had to chase the girl down to get it back.
Old Dec 30, 2004 | 09:12 PM
ToplessTexan's Avatar
ToplessTexan
Cruise-In II Veteran
Somehow I believe that.
Old Dec 30, 2004 | 10:20 PM
fat bob's Avatar
fat bob
2 questions:
Voide3, I just installed two Corsa systems. Had the same problem on the first system and called Corsa. Spoke to Paul. I explained that I had used these same clamps on many Harleys. He told me to tighten them "as tight as I needed to" to stop the muffler from moving. Also something that I learned while working, the mufflers tend to move out of the pipe and unless you have them in the pipe all the way, they will not tighten up. After doing the above, no problem. After a couple of heat cycles, retighten. In my opinion, the torque spec is too light. There is a spacer in the clamp (same as the Harley) to prevent damage to the pipes. I hope this helps you. I worked for me.
Bob
Old Dec 31, 2004 | 02:06 PM
fat bob's Avatar
fat bob
Bob
Voide3, I read this thread again and just didn't want you to have to weld your system if you did not have to. I was convinced, as you are, that the clamps would not hold with their setting and this is true in most cases. Before you weld, I would suggest calling them to verify the information that I gave you above. I tightened them up the old fashioned way until the mufflers would not move as they told me to do.
They have not moved since. See the post by "faaty go" above.
Bob
Old Dec 31, 2004 | 02:16 PM
runamuk's Avatar
runamuk
Cruise-In V Veteran
St. Jude Donor '04
I had mine installed for 6 months with no problem then one day 1 of the tips started to sag and the clamp wouldn't tighten up so I had them tacked in place, I have had no problems since
Old Dec 31, 2004 | 03:50 PM
BHP's Avatar
BHP
Same issue with the pass. side. Had to retighten many times. Make sure pipe is all the way in.
Old Jan 2, 2005 | 03:17 AM
Voide3's Avatar
Voide3
Bob
Thanks Bob. Before I read your post I called Corsa. I just happened to get Paul. I have applied more torque to the clamps. That seems to be working. I heated up and cooled down before adding torque. I will check and see how it does periodically.
Old Jan 2, 2005 | 08:13 AM
Capt.RobC5's Avatar
Capt.RobC5
The clamps are junk!!! BPP broke two clamps trying to tighten them down tight enough to keep the tips in place, Even after that, the drivers side fell off on my way home from Breathless. I immediatly went to my local muffler shop and had them welded
Old Jan 2, 2005 | 12:51 PM
hhntr111's Avatar
hhntr111
I've had the same problem with my Indy's. After almost losing the left muffler because of a loose clamp, I had them tack welded. For some reason, they still seem to have flexed, maybe because of engine torque. Last summer, at Corvettes at Carlisle, I stood behind the car during the rev salute to Chip Miller. My pipes, then still stock, and everyone elses, were twisting, I think left up, right down.
So I'm going to get the tack welds ground off and try again with the clamps, so I can adjust the pipes from time to time to keep them even.
Anyone else have this issue?
hhntr111
Old Jan 2, 2005 | 04:38 PM
fat bob's Avatar
fat bob
Voide3, glad to hear that. With all the problems that have been reported, maybe Corsa would do well to have a look at the dimension of the clamp and change it slightly to be more effective. The Harley clamps that I mentioned that are similiar in construction, are built so as to limit the clamps ability to "overtighten" and thus deform the pipes which on the Harleys are much thinner. I removed the spacer on the Harley clamps and then used a "reasonable amount of torque" to tighten without doing damage. Until I called Corsa, I thought that I would have to do the same thing to the Corsa clamps until Paul said to "tighten them up" . I hated to have to weld an adjustable system.
Glad it worked out and maybe the discussion will help others.
Bob
Old Jan 2, 2005 | 08:38 PM
leaftye's Avatar
leaftye
Bill, did you get a chance to get some pics?
Old Jan 2, 2005 | 10:26 PM
servohead's Avatar
servohead
Anyone here have these problems with the borla stinger system? I just bought the stinger kit, and plan to install it next weekend, I thought the clamps that the stingers come with look plenty sufficient for holding. Anyone?
To Can Corsa Torque Clamps hold?
