Key FOB question
Old Dec 31, 2004 | 07:41 AM
skyman51's Avatar
skyman51
Default Key FOB question
What is usually the problem if the the key FOB works unlocking the drivers door but not the passenger door when clicked a second time?
Old Dec 31, 2004 | 10:10 AM
ROCKnROLL's Avatar
ROCKnROLL
Veteran
It could be the door control module (DCM) inside the passenger door.
It's somewhat a common problem on the C5s.
I'm sure someone else will jump in with more details.
Old Dec 31, 2004 | 11:34 AM
Grand Slam's Avatar
Grand Slam
The passenger door seems to be temperamental. GM replaced the DCM once but I eventually had trouble with it unlocking, again.
Recently, the door had to be disassembled for maintenance and when it was reassembled the door started working correctly again. The DCM wasn't replaced so something must not have been making a good electrical contact.
To Key FOB question
