Which cam for my A4?
Old Jan 1, 2005 | 07:09 PM
JSTAN's Avatar
JSTAN
Default Which cam for my A4?
I am considering installing a H/C package in my C5.
Currently I have the following mods:
3.42's
SY3500
Transgo
Borlas
Kooks LT
Vortex Intake
I am considering the following two cams:
224/224 .581/.581 112
or
228/232 .588/.575 113
Can anyone with an A4 running either cam chime in and tell me how the car runs? Pros/Cons
Old Jan 1, 2005 | 07:18 PM
Fastbasser's Avatar
Fastbasser
Mine was 224/.580 on 114 and was great! From what I read 112s are more for M6s..
JMHO
Old Jan 1, 2005 | 07:27 PM
vstella's Avatar
vstella
Originally Posted by JSTAN
....224/224 .581/.581 112 or
Go with the later I've had that cam...Great low end and street power ..matches your gears!! Go 4 it!
See my CF homepage below for videos when I had that cam..hi 11's!!
Old Jan 2, 2005 | 06:45 AM
MC98's Avatar
MC98
3.42's
SY3500
Transgo
Borlas
Kooks LT
Vortex Intake
or
Who's heads will you be running? If I were you I would talk to who ever has done your heads and find out which cam performs best with their heads.
Another thing to consider, since you have an A4 you also have to consider the stall & the gearing that you are running. A big cam might produce more peak HP, but might not perform as well as some smaller cams. Because the stall is a bit too low for the bigger cam to perform at it's best. In general big cams run great with lots of stall.
Old Jan 2, 2005 | 02:48 PM
JSTAN's Avatar
JSTAN
I am considering purchasing a set of ForceFed High Performance LS6 sytle heads. With a SY3500 stall converter and 3.42's do you know what the ideal cam would be? This is my daily driver during the summer so I dont want to go to big on a cam, but am looking for 400 rwhp.
Old Jan 2, 2005 | 02:54 PM
'06 Quicksilver Z06's Avatar
'06 Quicksilver Z06
This will be your daily driver? Since you will be looking for a transmission soon, have you had time to narrow your choices? FLP, Rossler, Crashed 94?
Old Jan 2, 2005 | 02:59 PM
JSTAN's Avatar
JSTAN
JMHO
Do you have any dyno #'s with your setup?
Old Jan 2, 2005 | 03:19 PM
kirbyloid's Avatar
kirbyloid
Default cam
3.42's
SY3500
Transgo
Borlas
Kooks LT
Vortex Intake
or
Check signature for my setup we are close
Old Jan 2, 2005 | 03:55 PM
Honez's Avatar
Honez
I would always recommend a split duration cam especially if you think you will ever dabble with a blower, turbo, or Nitrous. If you have to pass a smog siffer in your state then you need to stay with an LSA of 114 or higher, and don't go over 224/224. I have a 224/228 581/588 114+2 sitting on my bench right this moment that I will probably install in my M6. This is a great cam and with good tuning will sqeek by the sniffer test. Here is CA it's about as agressive as I can go and still hope to pass.
Old Jan 3, 2005 | 08:17 AM
03SpiralGray's Avatar
03SpiralGray
I would not put in a cam with a lower lobe seperation than 114. I had a cam with a lobe seperation of 112 and could never get it tuned right.
Old Jan 3, 2005 | 08:40 AM
MC98's Avatar
MC98
ForceFed High Performance, sounds like they do FI applications. I would definately get in touch with them, and talk to them about your setup and which cam to run. A set of heads that works well with FI applications might not be the best heads for NA applications.
A moderate cam with a duration of 224-228 and a lift of 560-580 or so would be fine with your setup since this is your daily driver. Go with a 114 LSA since you have an A4.
Old Jan 3, 2005 | 09:04 AM
sprinter's Avatar
sprinter
Why not ask the meaning of life ...?
Old Jan 3, 2005 | 10:26 AM
Fast one's Avatar
Fast one
What does 114+2 LSA mean?
Old Jan 3, 2005 | 11:14 AM
99 vett babycar's Avatar
99 vett babycar
See my sig. I'm very close to your setup and very happy with the combo and find it's great for a daily driver. But the heads you put on will make a difference; I think you should consider heads and cam a "package" and make sure you pick a set up that works well together. As far as choosing between the two you mention I wouldn't go much bigger than 224 for a daily driver. But hey, it's your money so if you want to go bigger - Go bigger.
Old Jan 3, 2005 | 11:54 AM
JSTAN's Avatar
JSTAN
Thank everyone for the advice. What does the +2 mean in 114+2 LSA?
Old Jan 3, 2005 | 05:40 PM
Vector's Avatar
Vector
I have a 224/.581/114 and it is very streetable. See sig for complete mods. Idles @ 750rpm with some lope and no stalling!
Be sure to get a good tuner - it will make all the difference!
Old Jan 3, 2005 | 06:20 PM
GORDON
Guest
Posts: n/a
I have the sy3500 and 3;42 gears with 224/224 581 cam IT is very streetable.
Old Jan 4, 2005 | 02:31 AM
MC98's Avatar
MC98
+2 means 2 degrees of advance is ground into that particular cam. The advantage in doing this is you will reach peak power at slightly lower RPM in the power band.
To Which cam for my A4?
