You should do in a diagonal because the car has a cross-circuit system where one chamber provides fluid for one front caliper and the opposite side rear caliper. Doing the "cross-circuits" in sequences reduces the chance of leaving air in the system.
Remember never let the master cylinder run dry and I recommend replacing the reservoir cap when applying pressure to reduce air intake and reduce moisture absorption.
According to your profile you have a '98 so the above method is wrong. The correct method for a '98 is RR, LR, RF, LF (in other words, start at wheel furthest from master cylinder then work your way closer).
HTH,
Crash
That's the way I did my '99, and I'm pretty sure I read the manual before doing it.
