Frost King: Foil Insulation
Old Jan 3, 2005 | 03:12 PM
ROJ#79's Avatar
ROJ#79
Default Frost King: Foil Insulation
Question to those that installed this inside there cars.
Did you cement it in place or just lay it in?
Did the orginal carpets still lay flat in place after doing it?
Thanks in advance for the information.
Old Jan 3, 2005 | 03:26 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
The FROST KING insulation foam material comes with an adheasive already on the foam. The adheasive is not permanent, just stickey and the foam can be removed at a later date and or removed and repositioned if necessary. I recommend letting the rolls of insulation sit in a warm area prior to using it so it unrolls off the roll better.
It is very thin and there are very few places where it interfears with carpet fit. I layed it on the tunnel sides and top plus added the foil covered bubble wrap on the sides of the tunnel to help keep the heat out.
I found that it made the carpet contact the sides of the seat, sooo I cut the bubble wrap out where the seat bolsters rub the carpet. it worked wery well.
It was a very worth while mod with very noticible and rewarding results!!
Bill curlee
Old Jan 3, 2005 | 03:30 PM
atz06's Avatar
atz06
I used a total of 8 rolls for my Z which included double layers in some area and the door panels too. No problem with carpet at all.
Old Jan 3, 2005 | 06:28 PM
Mike04's Avatar
Mike04
Great stuff, no need to use any glue or cement.
Old Jan 3, 2005 | 06:47 PM
12stepvette's Avatar
12stepvette
St. Jude Donor '03-'04-'05-'06-'07
Great stuff!!
Used aluminum tape for the seams, and it can be easily removed if need be.
Old Jan 3, 2005 | 07:08 PM
msuc5vette's Avatar
msuc5vette
Did my entire interior including bubble stuff and frost king around the tunnel. Heat transfer is gone!
The only spot that gave me trouble fitting back together were the trim piece over the front bolts for the seats.
Old Jan 4, 2005 | 03:52 AM
Rob 99's Avatar
Rob 99
I'm "Apache" a psycho dog
I used 4 rolls, had no problems placing the carpet back, just kneed and press it in place with extra attention in the corners so the carpet dosn't bulge, cut the noise a bit, nothing revolutionery though.
Old Jan 4, 2005 | 10:18 AM
carpe dm's Avatar
carpe dm
Where did you guys get the Frost King? I'm having trouble finding it in Tucson. Thanks.
Old Jan 4, 2005 | 10:21 AM
Wicked Weasel's Avatar
Wicked Weasel
St. Jude Donor '05-'08
I got it at Lowes, but I think Home Depot carries it too.
Old Jan 4, 2005 | 10:26 AM
Mike Mercury's Avatar
Mike Mercury
same here; both carry it. Lowes and Home Depot have it in the heating/AC section.
You should be able to go to Lowes service desk and ask them where SKU #28929 is located.
Old Jan 4, 2005 | 12:05 PM
yooperod's Avatar
yooperod
fwiw, Home depot has free shipping until 01-05-05
I ordered my rolls online, last night.
thanks for all the info
rod
Old Jan 4, 2005 | 02:14 PM
Wicked Weasel
If you are doing this Mod, which is great, wear gloves because those little foil ends can really leave some nasty cuts (ok my hands are delicate and those cuts hurt - here comes wussy....)
Old Jan 4, 2005 | 04:29 PM
USA-VET's Avatar
USA-VET
Old Jan 4, 2005 | 04:39 PM
ROJ#79's Avatar
ROJ#79
Thankx Guys for all the help and info!
Old Jan 4, 2005 | 04:56 PM
JACKAL0PE's Avatar
JACKAL0PE
Lepus-temperamentalus
You can order it online from Home Depot.
Frost King Order Page
When you get to the link, do a search on "duct insulation"
To Frost King: Foil Insulation
