HVAC Display Installation
Old Jan 4, 2005 | 02:55 PM
majbillgsd's Avatar
majbillgsd
Default HVAC Display Installation
I'm going to replace the HVAC display on my 98 C5. How difficult is it to remove the console cover. I believe I will need to remove the cover so I can then unscrew the two screws holding the display then unplug and plug in the new display and reset the console cover?
Thanks,
Bill
Old Jan 4, 2005 | 08:25 PM
Nelson V.'s Avatar
Nelson V.
Here's a Tech Tip the removal of the stock radio. It'll get you as far as you to get to the HVAC controller.
(BTW, I am looking for a DEAD dual-zone climate controller. Is that what you are replacing?)
NV
Old Jan 6, 2005 | 10:47 AM
drejoh's Avatar
drejoh
5th Gear
I just replaced my hvac controller. If you want my dead one, let me know. It took me 15 minutes to replace it. And that's because I had to remove the dash part a second time.
Old Jan 6, 2005 | 11:31 AM
atl97vette's Avatar
atl97vette
From: You want HOW much for that Corvette part??? Atlanta GA
a fairly straight-forward and easy job. follow the instructions in tech tips and you'll have it done in less than an hour.
To HVAC Display Installation
