The steering wheel looks like I'm turning to the right just a bit. However, there is no wear on the front tires and it doesn't seem to pull abnormally to the right or left.
What the heck is the deal here, and can I straighten the wheel myself?
Yes that is an easy fix and will probably only require a 1/4 turn on each of the two tie rod ends (counter clockwise). The tie rod ends attach to the knuckle behind the rotor and have a lock nut to keep the rod ends from turning. Good Luck
Mine was doing the same thing. The three bolts on drives side bearing hub had come loose. I took the bolts out put lock tight on them and retorqued the bolts. The steering wheel was centered again after that.
FYI, One bolt had come out already and the other two were 1/8" loose, very close call.
Check that out, if all three come loose your tire, wheel and everything else will no longer be attached to the car. 3 wheels don't look good on a vette.
Thx!
If all connections are tight, you most likely are in need of a GOOD alignment. I would STRONGLY suggest that you NOT start adjusting your front end yourself unless you have the proper alignment equipment. Simply turning the tie-rod ends is not a safe fix without checking the ENTIRE alignment!
Unusual tire wear due to a bad alignment will take some time (and miles) to appear. The tolerances on a front-end are too tight to "eye-ball". You REALLY need the equipment!!!!!
