Aligning my Corvette hood??
Old Jan 5, 2005 | 09:34 PM
Z06FlyBy's Avatar
Z06FlyBy
Default Aligning my Corvette hood??
I think I'm gonna go outta my mind. Had to get a new hood and the dealership is a bunch of ******* a$$es. Any tips for aligning my hood on my car? It looks like it's centered but the passenger side gap between the hood and the fender is like twice that of the other side. The fender is adjusted in as far as it will go. Is this a bad hood or what?, it sucks bad.
Old Jan 6, 2005 | 01:53 AM
Shylor's Avatar
Shylor
Well mine came from the factory not aligned perfectly. All this talk about build quality being so much better with the C5 has me wondering.
I think you just have to adjust it a little at a time to get it right.
Old Jan 6, 2005 | 09:22 AM
sbright's Avatar
sbright
Default hood allign
Maybe it's your fender that's out... When I put my RK Sport hood on, I had to shim it up with washers under the hinges. Good luck
-Stan
Old Jan 6, 2005 | 10:33 AM
Kenny94945's Avatar
Kenny94945
Fender or bumper alignment are good leads.
I read the drivers side fender to hood and front bumper cover drivers to center emblem are good. Therefore see above.
Is the rear of the hood in alignment across the cowl from fender tip to fender tip? That would bring you to an issue in the passenger front corner.
"Had to get a new hood" why?
Maybe a hinge or something else is bent?
Old Jan 6, 2005 | 10:48 AM
MrEracer's Avatar
MrEracer
Hood alignment is a complex set of compromises. Have you tried to realign the hinges to frame relationship? Also, make sure the hood latches and release mechanism is properly alligned. If not, they will shove the hood out of position when closed. The hood catch ('U' shaped) must fall directly over the latch slot. I like to do all the hood adjustments with the 'U' catches removed. Then install and adjust them last. This will insure that they are not causing the miss-alignment. Good luck.
Shirl
SDRE
Old Jan 6, 2005 | 10:59 AM
connellyh's Avatar
connellyh
After an assisination attempt on my Vette by an F350, I ended up with slightly bent frame and all sorts of pieces parts out of alignment. Long story short, the frame went back into tolerances on the first pull and the damage to the body was only to the paint. The problem I ended up with was that the head light covers would scrap against the hood when raised. Everything else looked correct and the lights were maxed. I loosened almost everything and moved things around until I had good clearences all around. It was fairly easy, I had it done in a couple of hours. Are my lines perfect? No. However, they are close enough so that you have to look for differences.
To Aligning my Corvette hood??
