Cut outs
Old Jan 5, 2005 | 11:01 PM
Irish Whiskey's Avatar
Irish Whiskey
Default Cut outs
Where in a header plus xpipe plus high flow cats system would you add cutouts? (electronically controlled) Clearance problems?
Old Jan 5, 2005 | 11:19 PM
NCxtrooper's Avatar
NCxtrooper
Old Jan 5, 2005 | 11:31 PM
Dr. Dan's Avatar
Dr. Dan
Just had mine installed before the rear crossmember (Think that's what it's called) After where the X-pipe bolts to the exhausts. There is a pic in QTP's Customer Cars section of their website...the yellow C5. I had the motors pointing outboard though. Haven't finished wiring them up and unfortunately have no pics of my own.
Old Jan 6, 2005 | 12:21 AM
Elite Engineering's Avatar
Elite Engineering
Supporting Vendor
St. jude Donor '14
Here are a couple good picture of Patches' set-up. (click to enlarge)
Old Jan 6, 2005 | 02:55 AM
mdhmi's Avatar
mdhmi
Dennis - ping MSU???Vette - he is in your neck of the woods (if memory serves) and has a mild cam + the cutouts.. That thing is way loud when you open up the cutouts. Good for an estimated 10 hp.
Mark
Old Jan 6, 2005 | 08:25 AM
Patches's Avatar
Patches
Thanks, Jeff.
Using the currently available electric cutouts, there really isn't room near the collectors. I attempted to use FLP's swap-in cutouts but, when I mounted the electric motors/valves, the clearance just wasn't there. I ended up putting them in the x-pipe as you see in the pics above. This was a custom install. You can now buy weld-in y-pipes from QTP along with their electric cutouts to splice right into your exhaust system.
Here's a shot of that setup.
To Cut outs
