Next Level Performance Base Installed 427 Packages, $14,595
Old Jan 11, 2005 | 09:11 AM
Mike@NorrisMotorsports's Avatar
0Mike@NorrisMotorsports
Former Vendor
St. Jude Donor '11
Hey Chris,
I am sure these guys won't stop until they get what they want.
Mike Norris
Old Jan 11, 2005 | 10:30 AM
Chris@East Coast Supercharging's Avatar
Premium Supporting Vendor
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In V Veteran
Originally Posted by Vette Doc
Hey Chris,
Mike Norris
Yea, no thanks to your deal
Old Jan 11, 2005 | 10:53 AM
DT's Avatar
DT
Wow, that's outstanding, especially considering it's an installed price! What would be the price difference for a C5R block vs. a re-sleeved LS6?
Thanks!
Old Jan 11, 2005 | 11:10 AM
Fastgenious's Avatar
Fastgenious
I have a stock 04 Z06 except for the Blackwing exhaust. What would be the best setup and cost for me if I want 475HP+? I would also like it to be an every day driver. I drive it maybe 2-3 thousand miles during the summer months. Driving or shipping the car down to you would not be a problem for me. I live in Wisconsin and own a condo in Naples. Thanks...
Old Jan 11, 2005 | 01:12 PM
Former Vendor
St. Jude Donor '11
DT,
To upgrade to the C5R block would add approx $4000 depending on what I can find one for. We have done quite a few with them and it is a nice piece for sure. The cost is just a bit over the top for most.
Fastgenious,
The pricing for you on the base package plus Stainless Works longtubes, Random Tech hi-flow metal cats & x-pipe assembly, underdrive pulley, lower temp thermostat, ported throttle body, Halltech TRAP (not a big believer in the Blackwing) and SPEC Stage 3 clutch with aluminum flywheel will be $18,129 installed and tuned. This will get you into a very driveable and dependable 475RWHP area and not have to run the car over 6400RPM. Feel free to call the shop or e-mail me if you have any questions or are looking to get started. We can have you ready for summer for sure.
Later,
Mike Norris
Old Jan 13, 2005 | 08:17 AM
bradfordjr's Avatar
bradfordjr
Originally Posted by CHRIS NJ C5
Wow, thats an amazing price using all the best parts to boot..
Chris,
Can you match this price?
If so, you're a lot closer drive for me.
Old Jan 13, 2005 | 08:51 AM
USA-VET's Avatar
USA-VET
Hey Vette Doc, are you a Supporting Tuner?
Old Jan 13, 2005 | 09:06 AM
Cruise-In V Veteran
Mike has been here for awhile as a supporting tuner..
Old Jan 13, 2005 | 07:22 PM
Former Vendor
St. Jude Donor '11
I have been a supporting tuner for about, oh 3 or 4 years and have actually done quite a bit of work for the owner of the forum Norris Motorsports is the old name and still don't have a new banner made to change it here. That is why I keep Norris Motorsports in the sig.
Mike Norris
Old Jan 14, 2005 | 06:31 AM
Phil DeJohn's Avatar
Phil DeJohn
I was there on Wednesday to have work done on a C4, Great Guy's, Great Shop, Great Work.
Old Jan 28, 2005 | 08:56 AM
bradfordjr's Avatar
bradfordjr
Hey All,
Heres what we have. This package is based on NO CORE EXCHANGE. the only componets required from your engine will be the front & rear covers, oil pan and valve covers. You can either store your current engine or sell it complete to recoup some of the costs of the upgrade.
Here is a component list for you.
New LS6 block with Darton Sleeves.
ARP main studs.
Diamond forged pistons & file fit moly rings.
Callies forged connecting rods.
Callies forged cranshaft.
Clevite77 bearings.
NLP modified LS6 oil pump.
Comp hydraulic cam (choice of grind).
Comp lifters (850 or 875).
Comp adjustable timing set.
Comp moly pushrods.
AFR 225 cylinder heads with spring upgrade.
New GM cam retainer plate.
ARP head bolts.
ARP cam retainer bolts.
ARP cam gear bolts.
LS6 PCV valley cover and hose assembly.
36lb fuel injectors.
Complete machine work, balance and blueprinting.
Cometic MLS head gaskets.
Remaining GM gaskets and seals.
Oil, filter and coolant.
Professional install.
Complete in house LS1 Edit chassis dynotune with air/fuel.
$14,595 installed, no exchange.
Mike Norris
Hi Mike,
Could you give me a quote on this package at the Uninstalled & Shipped rate please?
To Next Level Performance Base Installed 427 Packages, $14,595
