decals
Old Jan 6, 2005 | 08:32 PM
gmosley's Avatar
gmosley
Default decals
about to install air bridge decals as well as air bag cover and steering wheel decals
i cleaned them with the alcohol pad like it said and for some reason i got an extra o and r with my airbag decal
well they wont stick
so how did everyone else get theres on
its about 60 degrees here but i dont think thats the problem cause thet stick to my finger like crazy
so i need some help with this issue
thanks
Old Jan 7, 2005 | 12:52 AM
gmosley's Avatar
gmosley
Default anyone
any suggestions
Old Jan 7, 2005 | 01:00 AM
RandW's Avatar
RandW
Sticky part down, not on your finger Was the alcohol pad wet, sometimes they dry out and are useless. Also try heating up the area with a blow dryer a little, it might be a little too cold. Good luck Want to see pics when done, where did you get decals from?
Old Jan 7, 2005 | 01:41 AM
TheDVS1's Avatar
TheDVS1
I used a cotton swab soaked in alcohol to clean out the indented areas real well and had no problem. I made sure that I dried everything properly before attempting to stick on the letters. It was around 60 degrees here too when I installed. I don't think temperature is the problem. I tried to avoid handling them too much, since the oil from your skin will definitely cause the glue to weaken. Use a dry swab to make sure everything is stuck well after positioning the decal.
I'll say one thing about those letters though - what a PITA to install! One has to be VERY careful not to rip those babies apart in trying to get them positioned properly.
Old Jan 7, 2005 | 08:06 AM
TOOGECKO's Avatar
TOOGECKO
Is your pad soaked with Isopropyl alcohol as in for medical use? I found that denatured alcohol works much better. Made this mistake once and found out that I needed those extra letters! Go to your local home improvement source and pick up a pint can; works for anything that needs to be cleaned for decals, double-sided tape, etc. Also, use the cotton swab technique to really clean the corners of the indentations. That seems to work much better...
To decals
