condensation buildup in lens
Old Jan 8, 2005 | 01:05 AM
GeorgeZNJ's Avatar
GeorgeZNJ
St. Jude Donor '08-'09
Default condensation buildup in lens
I've always had a build up of condensation in the front clear lens area(running light/turn signal) I know how condensation happens, warm in cold out, but this never goes away, any thoughts?
Old Jan 8, 2005 | 05:57 AM
16Again's Avatar
16Again
St. Jude Donor '07-'12, '20
Many of us have this problem. I have replaced mine and still have it, along with very small cracks in the lens.
Bob
Old Jan 8, 2005 | 06:10 AM
Joe C's Avatar
Joe C
Bob
had water buildup from cracks in the front lens' of my late and great 2000 coupe. dealer replaced them under warrenty. ive have several friends that also had cracks in the front lens' of their c5's
Joe C - 2004 black/mod red z06, 85 silver/graphite z51 driver
Old Jan 8, 2005 | 12:04 PM
JackTsDBG's Avatar
JackTsDBG
You could remove the lens, dry them them out, then reseal the seams of the lens with silicone. My wife has a Maxima and I put clear F/R sidemarkers on it. Had condensation, then resealed them. Condensation went away. Cheap and worth a shot.
Old Jan 8, 2005 | 01:27 PM
GeorgeZNJ's Avatar
GeorgeZNJ
thanks everyone, i don't see ant cracks, but i'll take em off, dry em out and reseal
Old Jan 8, 2005 | 04:14 PM
quick99ls1's Avatar
quick99ls1
i have the same problem, it realy annoying too, but not as annoying as a fog light going out
Old Jan 9, 2005 | 11:23 AM
Corvette00Car's Avatar
Corvette00Car
This may sound backwards but I've had this problem with most of my newer headlights. Sealing it is impossible. Water vaper will get in every time the lamp heats up and then cools down causing a lower pressure in the headlight than outside sucking in moist air. The key is venting. I drilled a 1/32" hole in the bottom of the assembly and this cured the problem for ever. Be well all.
To condensation buildup in lens
