Driver side door lock is giving me trouble
Old Jan 8, 2005 | 06:28 PM
Joe's Eray's Avatar
Joe's Eray
Default Driver side door lock is giving me trouble
When I go to lock my car sometimes the drivers side lock wont work. If I press on it mulitiple times sometimes it will work. Whats wrong with it? Is this an expensive fix?
Old Jan 8, 2005 | 08:04 PM
sunvet's Avatar
sunvet
I have a problem with my passenger side lock not UNlocking (2000 vert), which has been reported before. Someone suggested that there's not enough voltage to drive the lock due to low battery voltage or bad connections. I took the inside door panel off to work on it, but it was just a bit beyond a DIY job. Since it's my passenger side, I don't worry about it too much, except that sometimes I have to unlock the door from the inside to let my passenger in.
Good luck.
Old Jan 8, 2005 | 08:23 PM
ROCKnROLL's Avatar
ROCKnROLL
Veteran
It could be the DCM (door control module).
It's a problem that is somewhat common on the C5.
Check for codes and see what you come up with.
Old Jan 8, 2005 | 08:59 PM
Evil-Twin's Avatar
Evil-Twin
St. Jude Donor '03-'04
There are two things that cause this problem.. one is the DCM, this is the most common problem, The other is a pinched wire that goes through the rubber accordion duct in the top of the door jam under the A pillar. look at the orange wire and the black wire for any crimps..
there is one door control module in each door...
Old Jan 8, 2005 | 10:24 PM
C7GrandSport's Avatar
C7GrandSport
That's what it was on my 2002. Replaced it myself. What do you want, the DCM is made in Mexico!
Old Jan 9, 2005 | 02:38 AM
Joe's Eray's Avatar
Joe's Eray
If it is the module is it expensive to replace?
Old Jan 9, 2005 | 02:49 AM
Dan_the_C5_Man's Avatar
Dan_the_C5_Man
If you are handy at all, you can replace it yourself (like I did). If I remember, it ran about 230 bucks for the DBCM.. The hardest part is removing the door panel.
To Driver side door lock is giving me trouble
