Tire Pressure Sensors Test?
Old Jan 9, 2005 | 09:22 AM
Too Slow '90's Avatar
Too Slow '90
Default Tire Pressure Sensors Test?
Is there any way to test the sensors off of the car? I have an extra set with sensors from an '01 which I was told were good. I have no way of testing them with my '98. Thanks.
Old Jan 9, 2005 | 10:00 AM
ROCKnROLL's Avatar
ROCKnROLL
Veteran
Yes you can check them off your car BUT it won't do you any good because 01 sensors won't work on a 98.
Old Jan 9, 2005 | 10:13 AM
12stepvette's Avatar
12stepvette
St. Jude Donor '03-'04-'05-'06-'07
Do the Sensor programing in the Tech section....Ignore the ones in the mounted tires and place the ones you want to test on top of or close to the existing tire positions.
But like Too Slow posted...they wont work on the earlier C5
Old Jan 9, 2005 | 02:59 PM
Too Slow '90
So I need to find someone with a newer vette to test them.
Old Jan 9, 2005 | 03:19 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Yep! If you do find someone with an 01-04 and learn the non mounted sensors, they will sync up but will read 0.00 pressure and display that all of the tires are flat!!
Bill
Old Jan 9, 2005 | 06:05 PM
Too Slow '90
Thanks Bill. Once again, you da man!
To Tire Pressure Sensors Test?
