allignment specs...help...
Old Jan 10, 2005 | 01:04 PM
ROMA 75's Avatar
ROMA 75
Default allignment specs...help...
I just lowered the car....and i am trying to put 200miles before the allinement...can someone help me telling me the SPECS...?
Also wich specs do you think are better...?
the standard for the convertible,or the one for the Z06?
Thank you in advance....
Old Jan 10, 2005 | 01:32 PM
BlueDragon's Avatar
BlueDragon
Depends on your driving style and tires.
RunCraps? Normal everyday street driver? Stay with stock Toe and Caster, maybe add just a tad of neg camber, but no more than a half degree total.
Non Run Craps and hot street driving go with the Z06 settings. Go to the neg side of the camber tolerance if you can.
Old Jan 10, 2005 | 01:34 PM
Umrswimr's Avatar
Umrswimr
From: Overwhelmed as one would be, placed in my position.... DFW, TX
St. Jude Donor '05
If you're still running runflats, stick to the stock specs. If you switch to non-runflats, you might consider going to Z06 specs. However, if you don't race I wouldn't worry about it.
Old Jan 10, 2005 | 01:39 PM
ROMA 75's Avatar
ROMA 75
Mmmm.....thanks guys for the replyes.....
I use still the stock Crap flats....in the future i will eventualy change brand but still run flat...and yes i drive it like i have just steal it so....
i guess Z06....specs.....
but please i need the actual numbers... ....thanks..
Old Jan 10, 2005 | 01:45 PM
Umrswimr's Avatar
Umrswimr
St. Jude Donor '05
By "race" I meant "autocross or roadrace".
Z06 specs will decrease the life of your tires and are not receommended on runflats because the added negative camber doesn't work well with the stiff sidewalls of the EMT's.
Stock C5 specs:
F:
Caster: 6.4-7.4 degrees
Camber:-0.7 to 0.3
Toe: -1/16" to 1/8" TOTAL
R:
Camber: same as front
Toe: -3/32" to 3/32" total
Old Jan 10, 2005 | 01:58 PM
BlueDragon's Avatar
BlueDragon
Ya beat me to it, but the Zo6 specs, will toast your run Craps rather quickly! That is why I said it the way I did. I think the max Camber for the RCraps is .5 degree. The tire side wall is to stiff to allow it to sit right with the neg camber. and any additional toe will cause the tire to run on the inside edge big time. You can chew up a set of run craps in just a couple of hundred to miles.
Sooo Unless you want to change really soon???
Old Jan 10, 2005 | 02:27 PM
ROMA 75's Avatar
ROMA 75
Thanks David.....i will then go with the C5 specs....
thank you for the advices
Old Jan 10, 2005 | 03:57 PM
Umrswimr's Avatar
Umrswimr
St. Jude Donor '05
To allignment specs...help...
