Knock Sensor Malfunction - Please help!!
Old Jan 10, 2005 | 01:17 PM
99HRDTP's Avatar
99HRDTP
Default Knock Sensor Malfunction - Please help!!
Can anyone help me out with a recurrent code P0332? It keeps appearing despite multiple DIC resets.
Can anyone post an engine schematic to show me where the knock sensors are, please? I hate to keep driving with a faulty sensor, but I don't know where to look.
All assistance is greatly appreciated.
Old Jan 10, 2005 | 01:27 PM
BlueDragon's Avatar
BlueDragon
Two sensors mounted in the valley cover right under your intake manifold! Go to http://www.ls1howto.com/ and look at the intake manifold swap. or the EGR mod. Good luck!
Old Jan 10, 2005 | 02:55 PM
Byter's Avatar
Byter
Before you go taking off your intake, take a look on the back of the intake on the driver's side. Typically you will see a wiring harness clipped on a bracket behind the intake and bolted to the intake. This is the harness for your knock sensors. It may have come loose. If not, disconnect it and put some dilectic grease on it. I've had to do that with other sensors, especially the wheel sensors.
That being said, I had a knock sensor failure too and I did have to remove my intake. The knock sensors sit in the valley cover on top of rubber seals (grommets?). One of my seals came loose and put oil all over the sensor. If you do have to remove the intake it may be a good time to upgrade to an LS6 or FAST intake.
Old Jan 10, 2005 | 11:47 PM
99HRDTP's Avatar
99HRDTP
Thanks for the ideas to both of you. Unfortunately (or not), I already have the LS6 intake.
Old Jan 11, 2005 | 12:26 AM
runamuk's Avatar
runamuk
Cruise-In V Veteran
St. Jude Donor '04
Do you wash your engine?
GM released a service bulletin for owners who had knock sensors faulting. Basically water would get on top of the valley cover and then run down into the opening the knock sensors sit in and corrode/short out the sensors.
The service bulletin says to replace the faulty knock sensor and then use RTV to build a dam around the openings of both knock sensors to keep puddling water out of the openings.
Old Jan 11, 2005 | 09:29 PM
99HRDTP's Avatar
99HRDTP
I've used detailing sprays before car shows in the past, but never water. My car is a daily driver with close to 70,000 miles on it, and the code just started last week.
Would having the LS6 manifold change the position of the sensor? Does the dealer need to know this info. if I need to bring the car there? Anyone have a picture or schematic that they can post from the service manual showing the sensor locations?
thanks.
Old Jan 11, 2005 | 10:35 PM
BlueDragon's Avatar
BlueDragon
No the manifold does not change the sensor position it is mounted in the valley cover under the manifold. Unless the dealer checks the stamping cover or notices there is no channel on the bottom of the manifold there is no other exterior indication that it is a LS6 manifold.
Did you check the connection at the back of the manifold??
If you did a manifold change there may be a chance that a wire got pinched. Go to the LS1 how to under manifold change and you can see the sensor mounting there or in the EGR mod section.
thanks.
Old Jan 12, 2005 | 02:21 PM
99HRDTP's Avatar
99HRDTP
Thanks, again. Will check it out.
Old Jan 16, 2005 | 03:03 PM
99HRDTP's Avatar
99HRDTP
I pulled off the fuel rail cover today and tried to find this harness. Things are pretty tight down in there. Deep to the injectors, I saw a blue capped interface near where you describe it to be. Is this the correct place to check for a loose wire?
Thanks.
Mike
Old Jan 17, 2005 | 10:40 AM
BlueDragon's Avatar
BlueDragon
No, around the back of the Intake manifold. I think you are going to have to pull the manifold anyway to get to the sensors. and the wires.
The two round things in the center are your knock sensors.
Old Jan 17, 2005 | 11:40 AM
99HRDTP's Avatar
99HRDTP
Bluedragon-
Thanks for the picture. That's what I needed to know.
Mike
To Knock Sensor Malfunction - Please help!!
