Lowering ?s
Old Jan 11, 2005 | 10:26 PM
VLVETTE's Avatar
VLVETTE
Default Lowering ?s
I would like to lower but not slam it. How low can I go before I need an alignment? How much of the bolt shows in relation to how far the car gets lowered? I would like to drop her about an inch at least. Any difference in the ride positives and Negatives
Old Jan 11, 2005 | 11:35 PM
corvette dave's Avatar
corvette dave
[QUOTE=VLVETTE]I would like to lower but not slam it. How low can I go before I need an alignment?
There is no way to answer that question. It depends where the alignment is set before lowering.
I can tell you this; any lowering will change camber, toe and probably caster.
If you want to drive the car without having the alignment checked, then have at it. I would not!
Notice I said have the alignment checked. If needed then have it aligned. You will never know until you get the car on the rack.
Money well spent.
Dave
