Replacing Brake lines
Old Jan 11, 2005 | 11:01 PM
gssZ06's Avatar
gssZ06
Default Replacing Brake lines
I know this is a novice question, but here it is. I purchased fom stainless brake lines from Rippie. When I install them, and have the lines removed, do I need to be concerned about draining the brake fluid from teh ABS unit? Of course, when I refill and flush the brakes, I will purge air from the brakelines, but what about the ABS unit?
Old Jan 11, 2005 | 11:27 PM
SNW Vette's Avatar
SNW Vette
Default Bleeding after replacing flex lines
Hi
I have replaced the flex lines and didn't need to work the ABS.
I think the only time you need to work the ABS with the TECHII is when you want to purge the brake fluid completley.
Good luck,
Steve
Old Jan 11, 2005 | 11:29 PM
gssZ06's Avatar
gssZ06
Default Thanks
Old Jan 12, 2005 | 06:55 AM
Lancer033's Avatar
Lancer033
if you don't let the master cylinder run dry, you should be fine with a normal bleed.
I did let it drain dry accidently once and was worried that i wouldn't be able to get all the air out, but it worked fine.
Old Jan 12, 2005 | 05:32 PM
John Shiels's Avatar
John Shiels
From: Buy USA products! Check the label! Employ Americans
get a few rubber caps at the auto store 3/8" I think to save the mess.
Old Jan 12, 2005 | 05:53 PM
John Shiels
To Replacing Brake lines
