Electrical Grounds
Old Jan 13, 2005 | 12:29 AM
willz30's Avatar
willz30
Default Electrical Grounds
I've narrowed it down to G201 thats causing me to have the crazy gremlins of the electrical world. But I can't seem to locate it, does anyone have a clue as to exactly where it is. I mean how to even get to it, if so pls provide information, thanks
Old Jan 13, 2005 | 01:25 AM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
The best that I can do for tonight at 01:15 in the morning is use a flashlight to highlight the place where the ground connector is.
Here is a picture of where it is located. The flashlight beam is highlighting the area where the connector is located:
Old Jan 13, 2005 | 02:14 AM
Cscokd's Avatar
Cscokd
wow Bill....what a guy...the ground junction connectors are behind the plastic molding right where Bill's flashlight is pointing. You have to remove the doorsill molding strip to get to it.
John
Old Jan 13, 2005 | 10:16 AM
stingray4me's Avatar
stingray4me
look here, there is also a link to where all the ground points are.
http://forums.corvetteforum.com/showthread.php?t=976812
Old May 16, 2005 | 01:08 AM
timf1954's Avatar
timf1954
I was looking for this ground point today but I wasn't sure how much disassembly was required. It would appear that the doorsill plastic piece is held in place with clips, do you just pull up on it to remove it? Any tool required, or just brute force?
Old May 16, 2005 | 04:51 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Yep. Just lift up on the seam near the rear of the front piece and gently pull up there are 3 metal clips that fit into the body. After it unclips, just pull it back and lift up.
BC
Old May 17, 2005 | 03:34 AM
timf1954's Avatar
timf1954
BC
Thanks Bill.
To Electrical Grounds
