exhaust removal
Old Jan 13, 2005 | 12:18 PM
2vetteguy's Avatar
2vetteguy
Default exhaust removal
i am going to replace the muffler on my 2000 vert with a B and B prt. system, what do i need to know are there any shortcuts i should be aware of? or is ther a site that tells me how or has pics? thanks
Old Jan 13, 2005 | 12:22 PM
EG@EnglandGreen's Avatar
0EG@EnglandGreen
Supporting Tuner
From: ================== Houston, Texas www.englandgreen.com ================== Necessary Evil™ __________
CI 6-7-8-9-10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14
Sawzall
Old Jan 13, 2005 | 12:31 PM
HummelS's Avatar
HummelS
My "shortcut" was paying my local muffler shop $54 to do the job.
Old Jan 13, 2005 | 12:34 PM
BudgetPlan1's Avatar
BudgetPlan1
St. Jude Donor '09-'10
Old Jan 13, 2005 | 12:36 PM
If you want to keep your stock pipes intact, you will need to get the car about 3' in the air. Other than that, it is a pretty straight forward swap. I didn't have the equipment to get the car that high, so I just had a local muffler shop do it. Cost was $50.
Old Jan 13, 2005 | 12:39 PM
bozo4onion's Avatar
bozo4onion
Really easy w/MN6. A4 may need sawsall surgery. However I paid $70 for my Z06Ti install. Easily worth the $.
Old Jan 13, 2005 | 12:45 PM
jrose7004's Avatar
jrose7004
Old Jan 13, 2005 | 01:01 PM
0EG@EnglandGreen
Supporting Tuner
Depends on if you have a MN6 or a A4 (manual or auto)
On both, just normal handtools, nothing special needed.
On the MN6, jacking pucks, jack, rhino ramps and jackstands. It should come off pretty easily.
On the A4, a Sawzall is a lifesaver - to cut out the factory system. I spent a while trying to wriggle out the old one - eventually I just cut it out.
In any case, unless you can get your car up about 36inches, you will probably have to cut out the stock system.
Mounting the PRT will take just a few minutes because they come in 2 parts!! Piece of cake.
Old Jan 13, 2005 | 01:12 PM
CE2004's Avatar
CE2004
Jack the rear of your car onto Rhino Ramps or a stack of 2x12's. (Gives you an extra 8" or so of clearance under the car so you can roll around easily.) Cut your stock exhaust in front of the mufflers. I used a Lisle 31500 Exhaust Cutter, to avoid sparks right under the fuel tanks. From there it's just remove and reinstall. Piece of cake!
Spend the muffler shop money on your next Corvette mod. The job is too easy to pay someone else to do it. If I can do it, anyone can!!
Old Jan 13, 2005 | 01:18 PM
Vetteran's Avatar
Vetteran
St. Jude Donor '03-'05-'06-'07
Corsa has good instructions for their exhaust. They should be pretty close
to what you need to know;
http://www.corsaperf.com/installC5Sys.pdf
Old Jan 13, 2005 | 02:29 PM
bioman's Avatar
bioman
I just did my Corsa's on Rhino Ramps.....just needed to cut pipe 4 inches from muffler and drop rear sway bar......no problem...spent longest part of project getting tip alignment and elevation perfect and symetrical.
Old Jan 13, 2005 | 03:06 PM
billiam01's Avatar
billiam01
Take from someone who has done it twice and that will be it: If you don't want to cut the pipes, getting the back of your vette high enough is scary. I was lucky the first time and not the second. I was using wood blocks to stack on the jacks and the car rolled a little, (creeped back) blocks collapsed, and I had jackstand in place so the car hit the jackstand and it was slightly damaged where the jackstand meets the jacking spot on the side. Not noticeable unless you look under there. Chassis area is slightly bent (sheet metal) and some plastic (body) damage. Could have been a lot worse. Just pay someone with a lift!
Old Jan 13, 2005 | 07:55 PM
Last C5's Avatar
Last C5
Some aftermarket exhaust suppliers provide instructions that include loosening or removing the rear supports of the system. DON'T DO IT! The old system will slide right out of the supports and the new system will slide right in and you don't have to risk losing one of the bolts up into the dark abyss of the rear facia. That and, as others have said, use caution in the jacking process.
Old Jan 13, 2005 | 09:35 PM
Poptops's Avatar
Poptops
Thanks for the tip ... I'm waiting on my GHLs via Big Brown Truck and don't need to make this install anymore difficult than it needs to be. I have a lift and have been wrenching of cars for years so I'm optimistic.
Old Jan 14, 2005 | 12:42 AM
Davesredvette's Avatar
Davesredvette
They way I saw it I could pay $50 to have them removed or cut them off and buy another set for $50 if I ever go back....Just cut em!!!!
Old Jan 14, 2005 | 12:52 AM
Stickman81's Avatar
Stickman81
Unless you have a lift, pay for the swap with a knowledgable mechanic. The rear of the car has to be high off the ground and makes for a hazardous situation using jacks/ramps/boards or whatever. The first guys (at a Chevy dealership) could not get the right side out on my A4 coupe. They started to drop the rear end out and got a couple nuts out before I stopped them. I took it to a great Vette Mech (at another Chevy dealership) and he did the swap in about 45 minutes.
On the A4 the right side is somewhat difficult to snake out from everything.
Just my 2cents -
Old Jan 14, 2005 | 01:24 AM
JNS's Avatar
JNS
St. Jude Donor '06-'09
Well, having helped (mostly moral support) remove a ZO6 exhaust last week I would definitely say to find someplace that has a lift. Very precarious getting the car up high enough to remove the exhaust without cutting. Didn't want to cut the ZO6 Ti exhaust since there is a fair amount of resale value in them.
Jeff
To exhaust removal
Old Jan 14, 2005 | 08:26 AM
Wicked Weasel's Avatar
Wicked Weasel
St. Jude Donor '05-'08
If you have the Car on 4 Rhino ramps the car is already up a good bit so raising it the extra distance, in my mind, doesn't seem like it would be that bad.
Am I mistaken?
Old Jan 14, 2005 | 10:31 AM
GMDGary's Avatar
GMDGary
Anyone who spends about $1,000 on new catbacks and can't see the value in having the stock taken off and the new catbacks installed for $50, especially when a lift is required, is a mystery to me. I do 100% of my own wrenching on my bikes, boats, trucks, tractors and cars, but not when they must be at least 3 feet off the ground; and I do it solely because its fun. Dirty, nasty stuff that's not fun goes to the dealer - like grease jobs and oil changes.
However, I plan on building a new 30'x60' garage this summer and it will have a hydralic lift.
Old Jan 14, 2005 | 10:38 AM
CE2004's Avatar
CE2004
The -only- reason to pay someone with a lift to do this job is if you want to save your stock exhaust. Maybe you leased the car, and need to restore it to original condition in a few years.
However, if you're getting rid of the stock exhaust because you don't like the sound, that baby is just going to collect dust in your basement or garage or shed. When you decide you're tired of the car, are you really going to jack it up and put the stock system on? I wouldn't...
Skip the lift, cut the stock exhaust off and throw it away.
I love my GHL Bullets. And the stock exhaust that I cut off of my Corvette was probably recycled by Waste Management.
