X-Pipe's, any difference???
Old Jan 13, 2005 | 06:44 PM
Darion's Avatar
Darion
Default X-Pipe's, any difference???
Title about says it. Are there any difference between them? I am ordering Borla Stinger and I see Borla has an X-pipe now avalible, any reason to go with, random Tech, Bassani, Magna Flow ect..?
Thanks in advance,
Pat
Old Jan 13, 2005 | 09:36 PM
hhntr111's Avatar
hhntr111
I don't think so...kind of hard to tell anyway.
hhntr111
Old Jan 13, 2005 | 10:11 PM
servohead's Avatar
servohead
I'm just looking for the least expensive one as they all look the same and do the same thing pretty much. The only one that looks different is the Magnaflow, which looks a little more restrictive in my opinion. Let us know what you find! Good luck.
Old Jan 13, 2005 | 10:46 PM
Lemansvette's Avatar
Lemansvette
I went with ghl's. They were polished and the price was unbeatable!
Old Jan 14, 2005 | 11:26 AM
Got uid0's Avatar
Got uid0
St. Jude Donor '17
there is a bit of difference, they all make your exhaust more quiet.
I have a corsa x pipe, i believe the basani that looks like it hase a box at the x meet point may flow a bit more than some of the others.
Id say dont use one unless you have excessive popping or you will be taking away from the natural sound that was meant from your exhaust change.
Old Jan 14, 2005 | 12:08 PM
jrose7004's Avatar
jrose7004
It may just be me but if I were buying Borlas I'd get a Borla X-Pipe! Just my .02!
Old Jan 14, 2005 | 12:31 PM
Fast one's Avatar
Fast one
They are different in size. For example the Corsa's have different length pipes on the input where others are equal. The SLP resonator x-pipe is longer and uses larger diameter pipe. If you don't have long tube headers and you'll be installing them in the future then choose an x-pipe that the header system will fit or is sold by them.
To X-Pipe's, any difference???
