I ordered K&N air filter... worth it?
Old Jan 15, 2005 | 09:15 PM
dbwade36's Avatar
dbwade36
Default I ordered K&N air filter... worth it?
Is there any gain at all by changing to K&N air filter? I ordered one, because, at least you can reuse them, but there isn't any diff. in HP is there? Should I change to a Z06 intake? Any gain there?
Old Jan 15, 2005 | 09:21 PM
ALLEGRO's Avatar
ALLEGRO
Lot's of discussion about that here, both the K&N and the Z06 box.
I don't like the K&N's because the oil finds it's way into the MAF and intake plenum...and who knows where else. Happened on my Trans Am GT.
Read here a few months back that someone had done dyno time and found the paper filter out performed the oil and gauze.
Whatever you think is the final answer.
Old Jan 15, 2005 | 10:41 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
I have a K&N in my 98 Coupe and my 02 Z06. They do perform better and I like the performance gain. Very easy to keep clean and if you do not over oil them there should not be a problem with oil on the MAF.
I will be installing a VARARAM very soon and will be selling my K&N. I also have an 01 Z06 air box and lid that I am going to post on the C5 parts for sale forum.
Bill
Old Jan 16, 2005 | 12:11 AM
Richin Chicago's Avatar
Richin Chicago
http://www.bobistheoilguy.com/airfilter/airtest3.htm
Old Jan 16, 2005 | 12:25 AM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Wow,, Excellent info!! I will still run my K&N filter!
BC
Old Jan 16, 2005 | 09:21 AM
GOOSE JR.'s Avatar
GOOSE JR.
The K.N. air filter is a great product but you probably not going to feel a change. The intake is a good power builder and with the K.N. you should feel a change.
Old Jan 16, 2005 | 03:38 PM
David426's Avatar
David426
If you want to save money do the ole zip tie modification (do a search on this and you will find a thread with instructions). for 99 cents. This eliminates the stock air box (what a joke). It will take you about 15 minutes. Anyone ca do this mod its ver very simple. It will not look as good as blackwing or some of the others that run $200 or more but it sure gives you a seat of the pants improvement over the stock airbox. 10-12 rwhp. Make sure you get the weatherstrip for $11.99 (Ecklers sells them as well as Westcoast corvettes). This will keep water out
Old Jan 16, 2005 | 05:21 PM
66427-450's Avatar
66427-450
Originally Posted by allegro
...I don't like the K&N's because the oil finds it's way into the MAF and intake plenum...and who knows where else......Read here a few months back that someone had done dyno time and found the paper filter out performed the oil and gauze.
i second that.
if i recall correctly, the dyno said < 1 HP difference between the std paper Fram and no filter at all??, so, if that's the case, how much can you gain with a K&N HP wise?. then there's the issue of the K&N not filtering as well as a good paper filter (some say it results in more silica in the oil, i.e., passed more sand thru it). not to mention the problems with to much, or not enough, oil on the cloth.
do some research and decide........ i run a std. Fram air filter on the LS-1, but do use the K&N HP1007 oil filter for it's balance of flow/filtration
Old Jan 16, 2005 | 07:15 PM
allanlaw's Avatar
allanlaw
From an '01 stock to an '02 or newer Z06 lid will give a little more power. I would stick with the paper filter, and just make sure you change it periodically.
Old Jan 16, 2005 | 11:00 PM
Dr.Ron's Avatar
Dr.Ron
From: 2007 Nat'l Corvette Challenge 11.50 index Champ. New Jersey
I ordered one...
Isn't it too late since you already ordered it??
I'd guess 0-4hp on a best case scenario...
Ron
To I ordered K&N air filter... worth it?
