How do I get in my trunk??!
Old Jan 17, 2005 | 12:26 PM
Tinker777's Avatar
Tinker777
1st Gear
Default How do I get in my trunk??!
Sadly, my dad died on Christmas -- Happily I now get to enjoy his 1999 convertbile . My problem is the battery was dead and I replaced it and now I can not get the trunk to open.
The crazy thing is that the manual says to pull a cable in the 'Rear Storage Compartment' ..... ????? ...... how can you pull a cable in the trunk when I CAN'T GET IN THE TRUNK??
I have no clue how to do this. thank you for your help
Old Jan 17, 2005 | 12:30 PM
chaase's Avatar
chaase
St. Jude Donor '12
Sorry to hear about your dad.
You can get to the cable by popping open the tonneau cover (or if that won't open reaching underneath it). The cable should be near the waterfall. (I am at work, so I am not positive of its exact location)
Chris
Old Jan 17, 2005 | 12:33 PM
PHPD7102's Avatar
PHPD7102
St. Jude Donor '14-'15-'16
Sorry to hear about your father.
There is a release button on the dash and on the remote. If your remote is not working try standing by the side of the car and hold down both the lock and unlock button at the same time, after a few seconds the horn should honk and the remote should work again. Good luck.
Old Jan 17, 2005 | 12:38 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Why cant you use the trunk switch that is located on the dash?? It is on the drivers side in the left side of the sterring column. If you have driving lights it will be the switch below that switch. If you dont it will be the only push button switch on that side.
You should be able to push the drivers seat back all the way forward, crawl in the rear compartment and the cable for the latck is on the rear bulkhead bear the latch It is a silver wire with a metal bead on the end.
Please let us know how you make out.
Bill C
Old Jan 17, 2005 | 12:49 PM
purrvert's Avatar
purrvert
Got a Y2K vert and its particular about having the parking brake set before it lets me get in its rear.
Old Jan 17, 2005 | 01:59 PM
ronwc's Avatar
ronwc
Or you can just put the ignition key in the door lock (only goes in half way) and turn it back and forth a few times and the trunk will open -
Old Jan 18, 2005 | 10:43 AM
C4TOMCAT's Avatar
C4TOMCAT
Default helpfull info from other forums
Secrets of the C5
C5 Secrets and Computer CODE
The little yellow "helper light" on the bottom of the rear-view mirror that illuminates the shifter area
That you can put your key in the driver's door and turn it twice towards the front to unlock the passenger door and a third time to pop the trunk.
That you can pop the trunk and also pop the gas cap cover by pulling on metal lines hidden in the back.
The little slotted cover on the dash behind the steering wheel is where the inside air temperature sensor is located.
All of the option codes are in the glove box.
Tire inflation recommended pressures are on the driver's door
The thing that looks like a little LED near the DIC buttons is a light sensor
The thing that looks like a little LED near the defroster vent is a UV sensor for determining A/C usage to compensate for the heating effect of the sun
The build sheet is in the front re-bar
If you leave your turn signal on, in about 1 minute it will start to ding (loud enough to hear over the stereo) to let you know you have old timers disease.
You can reset the oil life by pumping the gas pedal 3 times (but not with the engine running)
Hold down the reset button while on one of the trip odometers and it changes that reading to the miles you've traveled since last starting the engine.
Hold down the Active Handling button for 5 sec. to engage "Competitive Driving" on cars equipped with active handling (2000 and previous years must be stopped.)
If you pull the seatbelts all the way out while you're buckled in, they ratchet back in to hold you tighter into the seat.
Simply remove fuse #2 under the hood and your DRLs will be out permanently. Only thing affected is that when you unlock at night using the key fob your front turn signal lights and back up lights will not will not flash. Your front turn signals will operate normally, however.
The side-view mirrors can twist both forward and backward, decreasing the chance of damage if struck.
There is a release opening with a flap to let air out of the car when the hatch is closed. It is located just above the driver side rear compartment, behind the carpet and on the side of the car. Not that it really works well.
Also you can ground your amp to a screw/bolt that holds the rear middle compartment to the frame.
If you have a 6-speed car you can pop the trunk when the car is running by lifting the e-brake.
There is a spot on the driver side just out of the middle compartment under the carpet for the lug nut key. You should have a compartment on the drivers & passengerÂ's side (in the trunk) and a center compartment. On the left (drivers) side of the center compartment, on the left side where the center cover fits, there is an 'indent' that holds the wheel lock key.
If you turn on the headlights, then go to parking light position, the lamps remain up but the headlights are not left on.
If you have the passive entry feature: If you lock your keys in the car, wait a few minutes and then shake the car. That will unlock the car.
HUD has a shift light for manuals.
You can easily shift the M6 trans up or down without the clutch if you match revs. (Not great for longevity, however.)
You can eject the cd from the in-dash player without turning on any power. Don't even need key in the ignition.
The cruise will disengage if you purposely make sharp side to side turns while cruising at say 60-80 mph.
When the engine is shut off, you can get the odometer reading by turning on the parking lights.
You can program setting #3 (both memory buttons atonce) in the seat memory to run the seat back and steering wheel forward for getting in/out of the car with the engine running.
If you hate DRLs you can pull the e-brake ONE click and they go off
To How do I get in my trunk??!
