Power Window not working...help please
Old Jan 17, 2005 | 02:17 PM
John's vette's Avatar
John's vette
Cruise-In III Veteran
Cruise-In IV Veteran
Default Power Window not working...help please
My passenger side power window is not working. When I hit the switch I get a clicking sound. I removed the door panel and the speaker and can see the back of the window motor. I have seen some suggest you can tap on it a few times and it works. Well that does not seem to help me out much.
Any suggestions on removing the motor? Do I need to remove the plastic water shield with all the black tar stuff? Anything else I should try before I try to pull the motor out to replace?
Anyone know cost of new motor?
Old Jan 17, 2005 | 03:22 PM
Jeffvette's Avatar
Jeffvette
From: No more yankee my wankee, the Donger is tired!
Try slamming the door hard while holding the power switch.
A new motor was 170 roughly at dealer cost.
It is a easy swap, the hardest part is aligning the window properly.
Old Jan 17, 2005 | 06:42 PM
SEAMOORE's Avatar
SEAMOORE
I've fixed mine 3-4 times by tapping on the motor with a fairly heavy tool ( vice grips, channel locks ) while holding the down button down. It's worked fine for about the last year. I've also fixed a friends this way . Good luck.
Old Jan 18, 2005 | 07:33 AM
John's vette
I will try this again, maybe I am not hitting it hard enough.
If it needs to be replaced, I believe I may take it to dealer..I hate trying to work in a space I can't see.
Old Jan 18, 2005 | 07:55 AM
BT-01-vette's Avatar
BT-01-vette
There was a TSB on bad modulars on my 01 that the dealer took care of. Check on it if you have an extended warranty of some sorts, both sides were replaced
Old Jan 18, 2005 | 08:50 AM
rzurek's Avatar
rzurek
4th Gear
Happened on my '04 Coupe after two weeks, turned out to be a bad module and was replaced under warranty.
Old Jan 18, 2005 | 01:54 PM
Jeffvette's Avatar
Jeffvette
The only thing you can't see is the electrical connector. Everything else is accesible. It's a 60 minute job.
Old Jan 18, 2005 | 03:00 PM
John's vette
Hmm, between hitting it harder or the cold weather this morning the window is now working. I just hope that it don't stop as soon as I put the panel back on. Does anyone have an explanation of why this works? Does it just get jammed?
Old Jan 18, 2005 | 03:58 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
The passengers side window does not get cycled as much as the drivers. This seems to be a commom problem. Recommend raising and lowering it once or twice a week if possible. that might help. I recommend lubricating the metal piviot parts with some light machine oil and cycling it a few times while you have the door a part.
Bill C
To Power Window not working...help please
