Polished rims
Old Jan 17, 2005 | 02:50 PM
3xblkvert's Avatar
3xblkvert
Default Polished rims
Hey guys, just wondering what you guys use to clean your polished rims. I have a bunch of hair scratches on them, anyway to get these out, or mask them?
Old Jan 17, 2005 | 04:41 PM
Evil-Twin's Avatar
Evil-Twin
St. Jude Donor '03-'04
are they clear coated??? If so your out of luck because, anything you use to remove scratches will remove the clear coat.. then it gets ugly..
once clear coat is removed from sections of the wheels the aluminum starts to oxidize,, when you try to clean the oxidation it only gets worse as the uncleared areas get larger and larger..
If they are not clear coated I suggest either Mother's Billet , or Semi chrome. Both are found at motorcycle shops..
Mother's products are found at most automotive stores
Old Jan 17, 2005 | 06:13 PM
3xblkvert's Avatar
3xblkvert
sorry to sound dumb, but how do you know if they are clear-coated?
Old Jan 17, 2005 | 06:23 PM
9T3JIM's Avatar
9T3JIM
Try putting a couple coats of Zaino or NXT on them, should make an improvement.
To Polished rims
