Trunk refuses to open...
Old Jan 18, 2005 | 01:50 PM
aurik's Avatar
aurik
Cruise-In IV Veteran
Elite Member
Default Trunk refuses to open...
Apparently this cold has been adversely affecting the risers on the trunk of my 'vert. When I pop the trunk, I hear it release, but sometimes it just stays stuck shut, and I have to somehow force my fingers into the crack to get it open. Is this something with an easy fix, or is it something more involved?
Old Jan 18, 2005 | 01:52 PM
Ragtop_Rob's Avatar
Ragtop_Rob
St. Jude Donor '17
I know this seems simple- but have you tried popping the trunk, then slamming the door with the windows up?
Old Jan 18, 2005 | 02:05 PM
SteveDoten's Avatar
SteveDoten
Cruise-In VII Veteran
had the same problem saturday when i was removing the seat for foam replacement--tried to pop the hatch to install the roof(rem'd to get the seat out)and same thing--climbed inside under the hatch and pushed up when hitting the button, problem solved--currently 12 degrees in ct
Old Jan 18, 2005 | 03:49 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
The hydraulic struts are designed to hold the trunk open more than to open it. iI you live in a place that is below freezing like in CT (05 deg this morning!! ) The struts have even less ability to assist the trunk to open. If there is any moisture on the gasket it could be causing the gasket to stick to the lid.
Use some silicone spray on the lid and gasket, lubricate the latch mechanism with some light oil and see if that helps.
I always pop the trumk and shut the driverd door. The air pressure inside the car always pops the trunk up.
Bill
Old Jan 18, 2005 | 04:01 PM
andy82's Avatar
andy82
2017 C7 of Year Finalist
Bill
Old Jan 18, 2005 | 05:59 PM
aurik's Avatar
aurik
Elite Member
Bill
Will give that a try :-)
Old Jan 19, 2005 | 07:51 AM
CoolRunnings's Avatar
CoolRunnings
I just had this problem...operator error...cargo net was fouled in latch mechanism.
Old Jan 20, 2005 | 11:54 PM
coast7's Avatar
coast7
I believe there is a GM TSB just out to fix this common "trunk won't open" problem. The latch mechanism is slightly out of alignment. The fix requires some drilling to oversize the holes in the latch hold down bracket to permit it sliding into proper position.
Ask Mr. Goodwrench
coast7
Old Jan 21, 2005 | 12:38 PM
ptdrummer54's Avatar
ptdrummer54
CI 5-6-7-8 Veteran
St. Jude Donor '04-'05-'06-'07
NCM Ambassador
I have also heard others say the latch mechanism was loose on their cars...
Old Jan 21, 2005 | 03:28 PM
gmblack3's Avatar
gmblack3
Pull the carpet fwd from around the latch mechanism and use some WD-40 or your lube of choice on the spring. You may need to do it a few times.
Old Jan 22, 2005 | 12:05 PM
C66 Racing's Avatar
C66 Racing
Premium Supporting Vendor
As mentioned above, the best trick is to pop the trunk then shut the door.
But, some other things that may help is to lubricant the latch and screw up the rubber bump stops in the rear corners of the trunk a little as they may exert some upward pressure on the trunk to help pop it up.
__________________
C66 Racing #66 NASA ST2, SCCA T2
AMSOIL Dealer (Forum Vendor)
AMSOIL Preferred Customer Program (Members buy at Wholesale - a savings of about 25%)
Old Jan 23, 2005 | 12:04 AM
GTSLN97's Avatar
GTSLN97
Happens to me too. I put some armoral on the weather striping and now it opens... I guess it was just getting sticky??
To Trunk refuses to open...
