DTE Short Shafts
Old Jan 21, 2005 | 02:52 PM
430 LSX's Avatar
430 LSX
Default DTE Short Shafts
Has Anybody Used Them, How easy are they to install and Whats the Price.
Old Jan 21, 2005 | 03:26 PM
5 Liter Eater's Avatar
5 Liter Eater
St. Jude Donor '11
Speed Demon in Houston has them for $239. They are not TOO bad to install the long/left shaft. The right one is a little more involved as it's behind the spider shaft/gears. Both require dropping the rear carriage. If you're going through all that you may as well put in their new HD belleville posi washers too for $50. New output shaft seals are also a good idea.
Old Jan 21, 2005 | 04:48 PM
DTE Powertrain's Avatar
DTE Powertrain
Collections Hold
We have the short, right-side shafts in stock for $249 and they do require that you disassemble the differential down to the carrier assy. for the installation.
Old Jan 21, 2005 | 04:58 PM
Dope's Avatar
Dope
Resident moron
Hey Phil,
Just curious (it's winter, no car work anytime soon), but will you still warranty the rear if I do the install myself? Or would I be better off sending it out to you? How much will you charge to install it?
Thanks,
Dope
Old Jan 21, 2005 | 05:09 PM
DTE Powertrain
Collections Hold
Give me a call Monday (or I can call you if you wish) and we'll work something up for you.
(260)407-5455
Best Regards,
Phil- DTE
To DTE Short Shafts
