Replacing stock clutch...
Old Jan 22, 2005 | 12:45 PM
Blueyednd's Avatar
Blueyednd
St. Jude Donor '05
Default Replacing stock clutch...
I've done as many searches as possible on clutch replacement, but still have a couple of questions...
I'm at 418RWHP and my clutch sticks to the floor when pushing it, usually 3rd to 4th shift at high RPM...the stock clutch does not slip, it just sticks to the floor.
My buddy owns a speed shop and will install a new clutch for me for free... I don't go to the track very often and do not want chatter. He recommended upgrading to a Z06 clutch and doing the drill mod. Will the Z06 clutch hold 418RWHP?
I don't want to drop big $$$ like on the exedy, and I've read good things about the LUK Stage II, any comments, suggestions, thoughts... Also, should I replace the master while I'm at it? Thanks in advance...
Old Jan 22, 2005 | 12:49 PM
Fastguy's Avatar
Fastguy
St. Jude Donor '03-'05
If you are going to have it all apart, swap in a Z06 master and slave. This usally solves sticking pedal syndrome. The stock Z06 clutch should be fine unless you drag race a lot. You will find conflicting info on the drill mod. I didn't do it to mine and it ahs been fine for around 10,000 miles. I beat the crap out of my car, shift at around 6,400, and haven't had any problems.
Old Jan 22, 2005 | 01:46 PM
T_Vert's Avatar
T_Vert
iv egot a new z06 slave and master as well as a z06 clutch and my stock c5 pedal sticks to the floor. new fluid too!
Dave
Old Jan 23, 2005 | 09:59 AM
Blueyednd's Avatar
Blueyednd
St. Jude Donor '05
Thanks for the replies. Any other thoughts/suggestions?
Old Jan 23, 2005 | 11:44 AM
servohead's Avatar
servohead
Dave
Yeah but what is your setup though?
Old Jan 23, 2005 | 11:58 AM
T_Vert's Avatar
T_Vert
setup? What do you mean/ I have 4.10 gears, vararam and thats it.
Dave
Old Jan 23, 2005 | 01:36 PM
ragtopws6's Avatar
ragtopws6
Do the Z06 hydraulics, worth every penny IMO.
Stick with the Z06 clutch if:
1) You are NOT going to do further performance mods.
2) If you don't do 1320 too much.
If more mods are in the future, at least go with LUK II.
Old Jan 23, 2005 | 02:03 PM
mdhmi's Avatar
mdhmi
If your not a frequent drag racer and you plan on sticking around 400 rwhp I would go with a Z06 clutch + Z06 slave and master.
Cheers,
Mark
Old Jan 23, 2005 | 02:41 PM
LS1LT1's Avatar
LS1LT1
Cartek clutch www.cartek.net
Old Jan 24, 2005 | 11:44 PM
Blueyednd's Avatar
Blueyednd
St. Jude Donor '05
After numerous recommendations, I called Tom at Carolina Clutch. What a great guy to deal with! I was going with the Luk Pro Gold, but he recommended the Exedy single and gave me a price I couldn't pass up... I'll post results after the install and break-in!
To Replacing stock clutch...
