Check engine Light
Old Jan 24, 2005 | 12:53 PM
MIKEVT's Avatar
MIKEVT
1st Gear
Default Check engine Light
I own a 2000 convertible. My check engine light came on and has stayed on. Getting no codes or messages on display. Car runs fine. Has anyone seen this before. What can I do to turn off light myself without having to take to the dealer.
Old Jan 24, 2005 | 02:46 PM
jmzvet's Avatar
jmzvet
http://forums.corvetteforum.com/show...clearing+codes
Old Jan 24, 2005 | 02:53 PM
billiam01's Avatar
billiam01
You should take it in so the mechanic (certified and trained for late model Corvettes - usually called drivability techs) can use an analyzer to find why the light came on.
Old Jan 24, 2005 | 05:45 PM
runamuk's Avatar
runamuk
Cruise-In V Veteran
St. Jude Donor '04
Why take it to someone, you can do all of this yourself. Here is a link to tell you how to retrieve, diagnose and erase your codes.
Fault codes
Old Jan 24, 2005 | 08:14 PM
ronwc's Avatar
ronwc
Many times the check engine light is emissions related - sometimes just the O2 sensor - should be an easy fix for tuner with an anylizer -
Old Jan 24, 2005 | 08:26 PM
donnyonee's Avatar
donnyonee
auto zone will let you use their tool for free to read the codes and clear them.
Old Jan 24, 2005 | 08:44 PM
jmzvet's Avatar
jmzvet
The only tool you need is your finger to push a few buttons on the DIC.
Old Jan 24, 2005 | 09:04 PM
12stepvette's Avatar
12stepvette
St. Jude Donor '03-'04-'05-'06-'07
Go to the C5 Tech section and look at how to read and erase codes
To Check engine Light
