Help please Codes on a 97
PCM
P1571 this code is a always there no matter what, from the forum I think it is normal for a 97
P1626
P1644
BCM
B0844
U1040
IPC
U1040
Radio
U1016
I have run through the shop manuals and it looks like I am loosing power to the PCM/BCM or the data link connector is loose. Where are the Star connectors 1 and 2 located?
The car runs great but the ABS and TC turns off with a mind of there own?
Anyone else had this problem?
Thank you for the help.
P1626 - Theft Deterrent System Fuel Enable Circuit
P1644 - Delivered Torque Output Circuit
B0844 - BCM Temporarily Inhibit ABS
U1040 - Loss of Communications with TCS
U1016 - Loss of Communication with PCM
Sounds like you need a new TCS & BCM module.
- Matt
- Matt
It was very long, full of pot holes and very bumpy!!!! I had some VERY serious electrical issues with my 98 MN6 Coupe! All of the same codes and some of the same problems.
Fear not! There is an easy and almost FREE solution!!
Please read the post on "Electrical System Issues" that I posted a while back " http://forums.corvetteforum.com/show...al+information " and let me know what you think. You more than likley have some corroded chassis grounds that need to be cleaned.
I have helped about 10 people so far with this exact same issue with excellent results!!. Doing the Chassis Ground Maintenance is the very first thing that you should do and it is not complicated.
The other issue could be your battery and the battery terminals.
How old and what type of battery do you have?
Please disconnect both terminals, inspect the battery terminals, cables and clean them with a small wire brush. The terminals need to be torqued on the the battery with 11 foot pounds of torque.
Please let me know if you have any other questions. I have lots more troubleshooting information and pictures to assist you with this issue.
Bill Curlee
Taken every connection I can find under the the car and in the engine bay appart cleaned and placed diaelectric grease in the connections.
Cleaned the connections on the BCM and PCM like you would a PC. The PCM is loseing contact with the BCM. That is causing code B0844. That is the only code that would make my dash light come on. The rest of the codes look like they caused by the loss of communication also.
This has to be a loose wire some where, it is too random to be anything else. I can go for weeks with no problems then it will happen 6 times in a day, then stop for a week or so?
Thanks for the reply and the help,
BC
