Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: General How-Tos
- C5 Specifications by Trim
Important information to help you understand your Corvette.
[Z06] C5 Z06 Frequently Asked Questions(FAQ)
#82
Any ideas suggestions guys?
Thanks.
Hey guys!
Currently I need to replace front upper control arms.
Should I go for an OEM arms or buy a kit like in a link?
http://www.ebay.com/itm/aFe-PFADT-Se...1XkX-~&vxp=mtr
Thanks in advance.
Thanks.
Hey guys!
Thanks in advance.
#83
Supporting Vendor
Love this thread..
__________________
TMODCUSTOMS Specialty CNC Products
C5, C6 & C7
Performance Shifter Boxes
Upgraded Shifter Options
Zero-Slop Shifter Linkages
Don't replace your clutch without upgrading your linkage!
www.TMODCUSTOMS.com
info@tmodcustoms.com
C5, C6 & C7
www.TMODCUSTOMS.com
#84
Not sure if it was addressed in this FAQ thread but would anyone know what C6 Z51 parts cross-over to the C5? Speaking specifically about suspension (upper/lower control arms & sway bars), wheels/brakes (hubs, calipers, and rotors), and differential.
#86
Received 1,870 Likes
Good question. I wasn't aware of this being any kind of an issue, on these cars.
#87
Get Some!
https://www.corvsport.com/1997-c5-corvette/
This page can answer some of your questions. Compare Z51 to base, and then compare Z51 to Z06. My experience is not to get too wrapped around the axle about Z06 vs. other parts. Sometimes new parts and "better" specs are just marketing. After many miles around the NBR in my Z06 I got to drive a Z51 coupe just as hard as I drove my car, and the only difference I could tell was the 50 less horsepower. Of course, I'm an amateur and I know pros could tell a difference at the limit.
#88
Received 2,180 Likes
CI 6,7,8,9,11 Vet
St. Jude Donor '08
The GM injectors are NOT known for problems. As long as the fuel is clean, the fuel filter has been changed, they can last for hundreds of thousands of trouble free miles. Im sure that there has been some injector failures as with any other mass produced parts.
For the most part, the LS Injector is not a problematic part. Of all the C5 and C6 cars that I have worked on, not one had an INJECTOR related issue.
I own an 02 Z and when it was stock and slightly modded, the injectors were fine of 40K miles. Then I heavily modded it and changed injectors to the Green Top 42 lb/hr injectors for the higher flow rate and lower duty cycle. Sold the old ones to another C5 Forum Member.
The following 3 users liked this post by Bill Curlee:
