Why is skip shift a problem?
It was dead simple to install. Including jacking time, I was probably under the car for ten minutes. I used these instructions to lift just the rear of the car, slid under, and installed the kit. The hardest thing was zip-tying the old plug and it's new protective shell to the transmission. When I say it took longer to jack up the rear of the car and put it on jackstands than to install the elminator, I'm being serious.
If you can't 'step on it' leave it in 1st...I drive in traffic every day and never have an issue...if traffic is slowing before I can get through the cags range just leave it in 1st...nothing says you must shift. shrug.
Not a problem anymore
I appreciate the additional instructions and tips on how to get under the car. I am sure I will get around to doing this at some point because yeah, it's only $20 not because I ever actually had to shift from 1st to 4th.
Dana
1) Apparently you don't need the mod since you always shift at the right time even in the worst traffic area.
2) I have been driving a stick all my life and find the skip shift annoying. I like to choose my gear at any rpm. Further I am not looking for the light all the time so I find that I have shifted out of 1st and am then forced to go to 4th.
3) You do not need a lift to install. I installed mine yesterday by backing my rear left tire onto a curb. Then it is a cinch to get under there
If you don't want to put one in, then more power to you. It's your choice. If you don't want to be bothered with always accellerating past 2000 RPM and be able to shift into 2nd gear under any condition, then install the mod. It's as easy as unplugging a connector and sticking a cap on the end.
Hey S, how is that bad boy? I'll bet you're smiling
I can't say I've experienced the skip shift in the C6 (yet
Bought the CAGS eliminator, but haven't had the need to install it yet- never shift early enough or with a light enough right foot to be interrupted by it.
There's nothing wrong with killing the car a few times. I've let others (a very few) drive my C5 and the clutch engagement is non linear as you say, and it caused them problems. Once you get used to it, you don't even notice it. I believe the non linear nature is a result of the clamping force required in a 400 lb-ft application.
Now, for an on topic discussion: Shifting into 2nd gear at 1700 rpm is appropriate in instances such as when I'm driving in my subdivision, keeping speeds below 25 mph, I have several blocks to go, and I want to shift to second. Under certain circumstances CAGS will prevent this. In this case, keeping it in first gear causes unneccesary wear and I don't want to leave it in first gear for 1/2 a mile. I prefer to have total control of my shiftpoints. That's why I bought a manual transmission. You will find that CAGS only kicks in very seldom. However, I prefer never. There are other instsances where it is preferable to shift from first to second at light throttle. Say you pull out onto a busy road from a side street, you're not tearing out onto this road, you are easing into traffic and choose not to accellerate hard, because someone might suddenly change lanes in front of you and slam on their brakes. I'm talking about the normal precautions you use to avoid rear ending people. So, In this instance, CAGS forces you into 4th. Then all of the sudden you have Billy redneck fly up behind you in his monster 4x4. Now you can't just punch it while in second because CAGS forced you into 4th gear (actually, I can since I have the CAGS eliminator). Now the non CAGS eliminator folks will tell you that they won't have a problem because they left their car in first gear to begin with since they didn't want to be forced into 4th gear, they just drive around at 4000 rpm in first gear to avoid the skip shift. What happens if there's just enough traffic to force you to constantly speed up and slow down between 20 mpg and 30 mph. Are you just going to leave it in first? No, without the CAGs elim you'll probably make sure that you allow enough room in front of you 1 time so that you can accellerate up to 2300 rpm or whatever the threshold is, shift into 2nd, and then you're o.k. Until traffic forces you to slow down to 8 mph, forcing you to shift back into first. Then you start all over agian, looking for room to accellerate to the point that you can bypass CAGSs and shift into 2nd. Or you can spend $20 and 20 minutes and elliminate all of that B.S. forever. Or you can choose not to install the elliminator and tell everyone what a great driver you are everytime you are asked about the CAGS eliminator.
Fair enough on the guy's quote. I didn't take it as harshly, but I am also not as close to the issue nor have I really discussed it before. For those that have, especially more than a few times, I can see why it may have rubbed some the wrong way. Regardless, I think the discussion has remained at a civil level which is positive.
Not saying you are calling out the dup icon. My point here was to say that some of us (okay me) may have thoughts, comments, or ideas that run the gamut from potential merit to flat out stupid. Especially since those of us new to this beast have never engaged in conversation on this topic. Others who have been around, will carry baggage over from those discussions. Believe me, I get this. Having spent 5-years on S2K boards, I've seen the same...er...stuff posted hundreds of times. I don't think this thread was in anyway meant to attack people or their driving skills based on CAGS. Some may see this thread and say "oh $%^& here we go again". Hopefully though, this thread is more about discovering the reasons and driving habits rather than chastising people. For the most part, I think we have been successful.
Now, back to the regularly scheduled program. Thanks for your write-up on the issue. Quite helpful especially since I have less than a week behind the wheel on this thing versus you guys who have driven Vettes for years. I spent quite a bit of time on my commute this morning watching the tach to see what I was doing. I really think for me it comes down to the habits I picked up from the S2000. Frankly, I leave the car in gear for a long time. This is probably the reason my gas mileage sucks. However, the 9k limit has created some habits for me that might be detrimental in the Vette. The C6 is simply too damn quiet! I found myself numerous times in 1st gear going 30 or so for a while. Why? There is not the audio cue from the engine that I am so used to. My automatic responses are not in tune with the Vette yet. The thought of switching out of 1st gear in an S2000 at 1.5-2k RPM is laughable. Hell, you might even stall the car switching out gears that low (not really, but it's funny to think about) !
Thanks for the PM as well.
...works just fine..
Even in my C5 with the Corsa Touring (admittedly a fairly quiet system, but it's still louder than stock), I have to watch my tach because I can easily do the same as you described and leave it in a lower gear if I get distracted. The only time I use my ears to shift is if I'm running it up to redline in each gear.
All of that abundant torque allows you to shift at a very low engine speed if you want. It also allows you to slam your passenger's head back into the headrest if you wish.
If I am driving my C5 "easy", I upshift at around 2300 rpm, unless I'm in traffic as described above. I do take mine to redline regularly though. That abundant torque allows you to shift just about anywhere you wish. That's why I'm such a big fan of torquey V-8's . It's also what gives the LS1 / LS2 engines such good fuel economy, contrary to the myths that many hold for V-8's.Once again,there is nothing wrong with repeat topics. Not everyone reads the Forum every day. And there's nothing wrong with leaving CAGS intact if you want. It's your car.
Barry
I am actually getting worse fuel economy than my S2000 and I think the C6 is rated for better. Granted new engine that might need a bit of time, but I have also been taking it much easier during the break in than I would in my 5-year old S2000. I fill-up every other day due to my 90-mile round trip daily commute. My S2000 would take 7.3 gallons at the fill. The Vette is taking 10.3 gallons.
