High Performance Driving with a Automatic C6?
Old Feb 11, 2005 | 12:29 AM
RacerChris's Avatar
RacerChris
Default High Performance Driving with a Automatic C6?
Anybody take their automatic equipped C6 to the track or autocross yet? Was wondering how it performs given the rigors of the track?
Without manual control of the gear position, it would seem you would get upshift at unexpected points or even worst downshifting? I've seen this sort of thing cause spinouts on friends C5 Auto.
So how are people finding the Auto in a track setting?
Old Feb 11, 2005 | 12:35 AM
Short-Throw's Avatar
Short-Throw
RacerChris I'm curious too. A friend of mine purchased a used C5 last month. He was not fimiliar with the car. It was an Auto. I took a few highway ramps to show him the cornering ability and had trouble keeping the revs high enough to keep a controlled manuever. When I did lose the revs, I tried the throttle and the rodeo ride started. With my MN6, This has never happened. Well, Automatic mavens, what's the secret?
Old Feb 11, 2005 | 12:51 AM
FLC6's Avatar
FLC6
I just use the selector and shift manually.
Old Feb 11, 2005 | 01:05 AM
natejohn's Avatar
natejohn
ME2
I wish I had the nerve to disable the "downshift lock-out" button however. Trying to remember to push the button down costs me time.
hmm...would also be kinda cool to have that "locking" feature keep you from slipping into neutral........
Old Feb 11, 2005 | 01:40 AM
shopdog's Avatar
shopdog
Old Feb 11, 2005 | 09:02 AM
Lee6's Avatar
Lee6
before getting my C6 i ran my A4, '98 Z28 at the track for a total of 17 days and never--not once--had a problem caused by my auto shifting at some inoportune time....
me thinks it's just one of those self-serving myths coming from the M6 crowd.......really.......i had to listen to all kinds of crap about A4s at the track.......i just put mine in 3rd and left it there.......when exiting a turn, and getting on it, i would just make sure that i was almost straightened out before flooring it
by the way, i had excellent times in comparison to other drivers with M6 cars.....i felt it no disadvantage at all to have an A4....
Old Feb 11, 2005 | 09:42 AM
AU N EGL's Avatar
AU N EGL
That is what 2 of my freinds have done.
Old Feb 11, 2005 | 10:20 AM
sal3coach's Avatar
sal3coach
A friend of mine that autocrosses his C5 auto keeps it in 2nd most of the time--he runs at fairly high revs but does very well with just1-2
Old Feb 11, 2005 | 10:44 AM
Hoonose's Avatar
Hoonose
Left my C5 in 2nd, it ran good anywhere from 20-90mph. The engine braking at higher speeds is phenomenal!
Old Feb 11, 2005 | 10:52 AM
RacerChris's Avatar
RacerChris
Originally Posted by natejohn
ME2
Hmm, C6 rookie here... Whats the "Downshift Lock-Out" button? Where is it located?
Please keep in mind I only have an MN6 and have never driven an Auto on the track. But let me give you a scenario I am concerned about.
At the end of a short straight, there is a 90, followed by another 90, then a long straight. You enter the first 90 and go hard on the brakes, revs drop, but the other 90 is coming and you are able to maintain speed through the first 90, so you don't hit the gas hard. As you exit the second 90, you accelerate hard. Since you have maintained speed, the auto stays in second, but as you hit the gas, it downshifts into 1st and revs pop up fast. This is exactly what caused my friend's A4 to spin. I was right behind him with my MN6, but stayed in 2nd because I was already at speed. So power came on slower and I exited the turn in control.
How would this scenario be improved with the C6 Auto?
Old Feb 11, 2005 | 10:53 AM
catbert's Avatar
catbert
I have done serious autoXing in both manual and automatic Vettes. Truthfully, I found it easier to autoX an automatic, but I won season series championships in both. With the auto, you can concentrate more on steering and lines, and you get nice, even torque application out of corners. Since autoX is as much about precision as all-out speed. it's all about what a person can effectively control in a very busy environment.
Old Feb 11, 2005 | 11:00 AM
FLC6's Avatar
FLC6
Chris,
If you use the manual control on the C6, when you are in second, it stays in second EVEN if you floor it.
ie, if you’re friend was in second and he exited the corner and floored It, the car would stay in second and not downshift.
If you take your Corvette to a racetrack I would highly recommend manually controlling the gates. This could prevent unwanted shifts at inopportune times
Old Feb 11, 2005 | 11:11 AM
bangbgC6's Avatar
bangbgC6
I wondered about that before. Is the stock Auto shifter made to be able to be used that way without damaging it over time?
I can tell you from experience without some manual shifting input ability, the auto left to shift for itself makes for some hair raising moments in any type of aggressive driving.
Old Feb 11, 2005 | 11:12 AM
Mike Siska's Avatar
Mike Siska
Chris,
FLC6....I thought the new A4 had a shifting algorithim that allowed for "performance" driving at the track where it would stay in gear until you wanted it to upshift. Now I'm confused.
Old Feb 11, 2005 | 11:41 AM
TedG's Avatar
TedG
You are absolutely right. This has been in many articles. This is NOT a C5. From what I understand it uses the yaw sensor to detect if you are in a corner and will wait until it is the right time to shift. Sophistication gentlemen, sophistication.
Old Feb 11, 2005 | 11:46 AM
UBETRUN's Avatar
UBETRUN
I've been thinking about a ratchet type shifter for my A4, it's too easy to bump it past 2nd and into 3rd.
This is a good thread, please keep the info coming.
Old Feb 11, 2005 | 11:52 AM
RacerChris's Avatar
RacerChris
That is what I understood also. Anyone have first hand experience with it?
To High Performance Driving with a Automatic C6?
Old Feb 11, 2005 | 12:12 PM
PeterK's Avatar
PeterK
St. Jude Donor '12
2012 Election Contest Winner
I've heard that manual shifting of a corvette slush box (or any slush box not designed for it) results in a tranny failure. Is it myth or reality?
Old Feb 11, 2005 | 12:16 PM
FLC6's Avatar
FLC6
Pet,
I would like to know that as well. I know my buddy killed his Jeep that way.
Old Feb 11, 2005 | 01:05 PM
bangbgC6's Avatar
bangbgC6
The Algorithim works great except it doesn't know when you need to Downshift.
As soon as it has visual accuity programmed into it I feel it would be acceptable for performance driving situations.
The Algorithim does not see when when I am approaching a corner hot and want to kill off some speed without cooking the brakes. Plus the inaccuracy of using the throttle to bring on the downshifts is just plain dangerous. You are counting on your foot to make some desicions that are pretty fine in nature, even a slip of your foot can cause a serious problem in a hurry. Not that any of us ever drive where there might be bumps.
I own an A4 equipped car and I think it's great for cruising, but I'd get the Mn6 next time without thinking twice, more control I believe.
