problem
Old Feb 20, 2005 | 01:12 AM
c6nut's Avatar
c6nut
Default problem
Today, took the car for a ride. I was driving for about 30 min or so. I got on the expressway. Went through WOT 1st, 2nd then proceeded to 3td. The clutch stayed disengaged to the floor until the rev's came back down. When I let off the gas it poped back up. What would cause that to happen? Is that a common thing with a clutch. I have had only automatics in the past so I do not know if this is normal. I have 2,700 miles on the car and never had this happen before. Is it something I did wrong?
Help
Old Feb 20, 2005 | 01:26 AM
Cambria's Avatar
Cambria
I would take it back to the dealer ASAP. A clutch should not stick to the floor. It should follow your foot when you disengage
Cambria's Avatar
Cambria
Take it back to the dealer, should follow your foot when you disengage.
Old Feb 20, 2005 | 12:42 PM
Hoonose's Avatar
Hoonose
It happened to me once, the same way, about 2 months ago, but never again. Let us know what the they say or find.
Old Feb 20, 2005 | 12:43 PM
Alex Levy's Avatar
Alex Levy
Help
Same thing happened to me twice in 3 weeks.. I believe the clutch needs to be bled.. problem is that there is almost no way you will be able to reproduce it at a dealer and they will say "Nothing is wrong"
Old Feb 20, 2005 | 01:58 PM
c6nut's Avatar
c6nut
Did you bleed the clutch? Has it happened again? I will call them tomorrow and take it in.
To problem
