Reward!!! $500.00
Location: Austin, Texas Codes 660, 9448, and 295660 work in the C6 navigation unit. No DVD playback yet.
Originally Posted by PJinNJ
Maybe just a CAGS type of fix. If you notice, you can be moving too slow or short for the GPS to realize it so there must be a sensor that prevents it. Every GPS I own and have owned had this feature as selectable, THIS unit must be tied into the vehicle to sense movement, it's a GM thing not the NAV unit.
On the G35, there is a fix -- however, it's a little more complex than the CAGS fix (requires cutting several wires and hooking them up to a switch), but the problem is that the car won't properly "navigate" while you trick it into thinking that it's not moving.
There's a wire that transmits a signal to the nav to tell it the car is moving. It's a little more complex than an on/off switch, as it carries the speed (and possibly direction) of the car as well. This is all used by the nav to help pinpoint exactly where you are while driving. When you disable that signal, the navigation gets confused because the nav satellites tell it that it is moving, but the software inside the unit says that judging by the transmission, you aren't moving at all.
It's really a software fix. And here's the problem: the software is mostly embedded in the chips or encoded on the DVD. It's also custom software and you likely don't have the decompiler nessessary to understand it. If it's fixable on the DVD (which I doubt), then it's just a matter of figuring out the source and re-burning the dual-layer DVD. If it's in the chips, its even more difficult. You've not only got to understand what the programming actually is, you've got to figure out how to either flash the nessessary chips (requires a relatively expensive programmer and access to the chips) or how to replace them with preprogramed ones.
Could it be done? Sure, but don't count on it, and if it is done, expect to have to do some fine lead soldering with solder suckers and all those fun toys.
I'm hoping that maybe the 2006 Nav will be "fixed", and I can transplant that into my 2005 nav-equipped corvette.
It's not limited to GM or Corvette......I have a new 05 Grand Cherokee with Nav and, guess what...........you can't manipulate the system while moving......except for the basics as in the Vette system. But.....it's all in the name of safety......because you know there would be some "less than brilliant" driver out there that would be watching the screen and puts the vehicle through someone's front door!
I doubt they will change it though cause they don't want people staring at the screen while driving. Even though you can have a passenger that can use it without causing a driving hazard. So the situation is sketchy. If it keeps going this way soon we wont be able to change the radio station or cd or even a/c or heating controls cause it can be hazardous.
Originally Posted by JJayzX
Does the radio play mp3's at all or you just can't select while driving. cause if you can't just play them it could be the cd your using some cd players do not like certain cd-r's. Now if you can't cause is programmed to not let you browse thru folders or like the nav doesn't let you browse thru you would need to know alot about what they used to program it and how you would program it and what to look for and what to change it too. That is something for a hacker/cracker/modder like those people that learned how to mod xboxes and stuff and could take months to do. Sorry to say but you could be beat on this.
It does however play Audio CDs created on CD-Rs.
So it can read a CD-R, it just doesn't have the code to handle playing back MP3 files.
The 6-disc in dash CD changer that comes with the 1SB package DOES play MP3 files created on CD-Rs.
The $1400 "upgrade" to the Navigation system "demotes" you to a single disc only and with no MP3 playback capability.
Stephen
Originally Posted by shopdog
To make the factory Nav radio play MP3s, major hardware changes would be required (the Nav doesn't have an MP3 Codec, or any provision for switching one in and out of the circuit). The other things you want are "just software", but reverse engineering that would be a *major* job. Good luck on finding any takers at $500.
Offer me $50,000 and I'll gut your Nav and custom rebuild it to do what you want. I'd only do it that cheap because I want those capabilities myself, and so I'm willing to do the reverse engineering work way below market rate.
Now returning to the real world, the cheapest way to get what you want is to buy an already engineered aftermarket system and install it. For under $3,000, you can buy and have installed a system that'll do everything you want (except interface with the HUD).
I don't expect someone to engineer this from scratch. I know what the labor to reverse engineer the software in the unit and rewrite it would cost. I'm an engineer myself...
I was hoping to give an incentive to someone who either worked on the development of the unit, had inside knowledge of the code or the method by which it's "flashed" when fixes are found, or knew somebody inside Denso or GM who had done this. I'm SURE that Dave Hill's C6 doesn't have these limitations. As an engineer myself, I realize that my projects have "special" versions of code (for testing) that will be "sanitized" before it makes it to the end customer.
I specifically don't want an aftermarket solution. I like the integration with the HUD. I like the look and feel of the screen and buttons. I just want some extra functionality and one limitation removed. My wife's STS, which looks VERY similar in layout (because it's another Denso unit) DOES play MP3 files. It even uses the same Navigation DVD disc (I tried her "Cadillac" map disc in the C6, exactly the same.) So does the XLR, which shares a lot of development with the Corvette. What I'm looking for it NOT impossible.
Geez... why bash me? I'm putting up my own money to try to help find a solution to some problems that a lot of people are complaining about.
Stephen
Originally Posted by Z064life
As a competent engineer myself, I can make $200-$300 building someone's computer in ~30min. This problem is very complex. You need hardware changes and software changes. You have already stated any hardware changes come out of the reward.
$500 isn't going to give any competent engineer any incentive to do this.
If it gets done, it will be because someone wants it themselves and is willing to do they work for them.
Sorry, but good attempt at trying to get someone to work
Stephen
Originally Posted by dvarapala
If the nav CPU has enough MIPS, and enough code space in the flash, someone could conceivably implement a software codec. The source code for MP3 codecs are freely available.
Stephen
Originally Posted by rbl
What ya smokin man ....
It ain't impossible. It's already there in other GM cars with navigation units from the same OEM.
Stephen
Originally Posted by WhiteDiamond
We have a Nissan that does the lockout after about 3 miles per hour is achieved...I have bugged countless service departments with the Nissan logo above them to get this issue resolved so that my wife or passenger can access maps for lodging, food, or gas stations while we drive, but it fruits to nothing. I am ordering Nav on our C6 and it is too bad that this system is similar in locking you out.
I offered a solution to Nissan directly. Put a switch in the passenger area that only a passenger could hit(like the old high beams button on the floor, remember those?) and make the Nav operable with that.
Todd
Todd
Either way, I don't think it's gonna be a snipped wire to unlock the buttons. It should be easily accomplished via software though.
Stephen
Originally Posted by Superstar555
Take that $500 dollars and put it towards an aftermarket (I like Alpine) NAV system.
Problem solved.
Problem solved.
Stephen
I still say there's someone at GM or Denso who has the code to do this already. It's (MP3 playback) part of several other Denso supplied systems, it just doesn't make sense that the Corvette doesn't it.
And the speed related lockout... you'd think that the code for the Nav was written first and then the speed sensing lock added afterwards. Since Denso supplies several manufacturers, it'd be logical to think that they would "customize" stuff like speed related lockout to each company.
Stephen
Stephen
I still say there's someone at GM or Denso who has the code to do this already. It's (MP3 playback) part of several other Denso supplied systems, it just doesn't make sense that the Corvette doesn't do it.
Stephen
Stephen
#33
On other vehicles its fixable
A wire that tells it that the emergency brake is not on and a wire that tells the nav system that the car is moving prevent my system from being utilized.
I also dont understand why my passenger is not able to update the system while we are moving.
I agree with the other post about why not just disable all controls like a/c and radio unless you are stopped. Our legal system is going to hell in a handbasket more rapidly than we would like. The other day I saw a sign on the road warning us that the road will become wet when it rains!
And don't forget the McDonalds warning that their coffee is HOT! No Kidding... Is our IQ slowly dropping????
#34
Originally Posted by gellis
Take full advantage of the pre-set destinations (home, plus five others) that can be selected while you're driving. Also, POI's are selectable while driving (via voice).
You still have to be at the 1/4 mile scale or smaller or no POI icons are displayed at all.
And then you have to find what you want on the screen in the maybe 1 mile radius around where you are.
So the voice doesn't really solve much. It doesn't allow you to select and route to a POI that you can't see on the screen... And if you can see it on the screen, you can probably figure out how to get there anyway!
A common scenario for me is that the wife and I are taking a trip and are on the Interstate doing 75MPH. Let's say we want to find somewhere to get a pizza. There's really no way to find an italian restaurant while moving. You can turn on the italian restaurant icons via the voice recognition, but you still have to sit there and scroll around the countryside looking for one of those italian flag icons... and find it in time to take the exit to get to it.
Anyone know how to handle this type of situation? In the end, we end up watching for the real exit signs on the side of the road listing what's at the next exit and just keep driving until we find something we want... the nav system is basically useless in this scenario.
Don't get me wrong, if you know where you're going by address, phone number or intersection and route before you start out the system is top notch. It does a great job (at least in my area) of taking you right to the doorstep. Literally! I put in my home address and it routed me right to my garage door: "You have arrived at your destination."
Stephen
#35
Or better, they already have put a 400 HP 3200 LB weapon in our hands. We are being trusted to drive responsibly and not do 150MPH everywhere. Why is it so much more difficult to understand that a driver who can operate this car has the skills to NOT be distracted by what is really a very useful tool (the Nav system?)
Is our IQ dropping? Nah, we were smart enough to buy a Corvette in the first place. We have to be towards the top of the scale in that regard. Heck, a lot of us are smart enough to find this forum and have a intelligent debate about this stuff. In the end, a workaround posted to the forum would tend to only make it to the elite owners (us) anyway!!! The rest of the owners who aren't forum members can drive along with their Nav safely locked out!
Stephen
#36
I think in 06 will be mp3 compatible from what i've seen in the option sheets. I bet nav will be the same though. I don't really care if I don't touch the nav while driving though cause I don't like taking my eyes off the road cause of the idiots here, escpecially while driving in my vette. They try to run ya off the road.
#37
Stephen
#38
St. Jude Donor '06
#39
If you really want to watch movies in your car go buy one of those $100 DVD players at the discount store. Its a lot easier than trying to hack your NAV system.
#40
I do NOT want to watch movies in my Corvette.
I want to be able to carry around more than 1 audio CD
worth of music in the unit at a time. Changing CDs is a
pain. The non-Navigation equipped 1SB cars get a unit
that will play CD-recordable discs that contain your MP3
files. This means that you can get upwards of 10 hours
of music on one CD.
I'm just asking for that ability in my single CD player.
I never said anything about watching movies in my car.
I did say that my wife's Cadillac STS not only plays MP3s,
but also plays DVDs with DTS 5.1 surround sound, so I
know GM has this capability. Heck, her STS was about
the same price as my Corvette!
I'm the last to ask for an override to allow someone
to watch a movie while they are driving!!! I just
disagree with GMs belief that we are unable to have
a passenger operate the Navigation system to find
a gas station or a restaurant while I drive.
Please take a moment to read the thread before you
post something sarcastic about putting a $100
home DVD player in my car...
