CAGS Eliminator
You could do the 5 cent resistor from Radio Shack, but I recommend that you just go to one of any number of forum vendors and buy one for $19.95 so you get a nice unit that will weather protect the solenoid and wire harness.
It's a real quick and easy install.
The CorvetteForum Store and many other forum vendors have them.
Bob
But for 20 something bucks, it's worth it...
How can it not work? Isn't it true that when you hook up the resistor, the solenoid for the CAGS is actually disconnected from the wiring. I thought the resistor is to prevent a fault code.
When you install the CAGS eliminator it completely disconnects the solenoid. There's no way it will activate when the wire to it has been disconnected!
Bob
When I installed mine, I disconnected the wire harness from the solenoid on the transmission.
I then put a plastic cap on the solenoid to protect it from the weather. There is absolutely no electrical connection in that plastic cap, so the solenoid is completely and totally disconnected from the electrical system of the car. There is no way that it will ever activate again unless I hook the wire harness back up to it. It is not "interrupted" it is "disconnected".
I then put the other part of the CAGS eliminator on the end of the wire harness. This part has the resistor in it. You could leave it off and drive the car, but you'd get a "check engine" light because the system detects that a wire is not connected properly. To Avoid this "check engine" light, the part you put on the wire harness has a resistor in it that simulates the resistance the system would see with the CAGS solenoid connected, so the "check engine" light won't come on. However, because the system sees the proper resistance and thinks the solenoid is still connected, you WILL still get the "shift 1->4" light, but the solenoid is completely disconnected and will not activate, so you just shift into 2nd gear even if that light is on.
After you install the CAGS eliminator, there is absolutely no electrical connection to the solenoid. It is just a hunk of metal screwed into the side of the transmission. You could take it out and put a plug in there, but it's easier and cheaper to just put the plastic cap on the solenoid and leave it there.
It is not "interrupted", it is totally "disconnected".
Bob
There's just no way it can activate, intermitently or otherwise.
Bob
Bob
You don't know what you're talking about.
But, rude responses are uncalled for...
I've done the "standard" reply before (though not with the icon in question) and come in behind something I didn't even know was there. Occasionally makes *me* look stupid, which is why I go back and read threads after posting.
Cheers to all.
Conclusion: The guy is spewing garbage.
