steering problem
Old May 6, 2005 | 07:10 PM
dolphin2551's Avatar
dolphin2551
Default steering problem
Took my c6 to service for a noise and rumbling in the steering wheel when turning from a stand still told common on a automatic trans GM told service dept. to do nothing 54,000 dollars for a noisy rumbling steering wheel now I'm rethinking whether I should have bought this car!!! Especially when other people can hear the noise from outside!
Old May 6, 2005 | 07:24 PM
TedG's Avatar
TedG
Better get rid of it. What would the neighbors think?
Hoonose's Avatar
Hoonose
Now that's one I haven't heard of on this forum. It's coming from within the steering wheel, and not from under the hood?
Old May 6, 2005 | 08:18 PM
TYLERTONY's Avatar
TYLERTONY
I've noticed the same problem as well lately..only 1300 miles and auto too...anyone else?
Old May 6, 2005 | 08:27 PM
VNAMVET's Avatar
VNAMVET
Veteran: Marine Corps
Yes.....it started just after my dealer fixed my crank pully bolt issue.
It feels like its rubbing somewhere near the steering column and I can feel a vibration through the steering wheel along with an iritating noise when turning th steering wheel..............
Old May 6, 2005 | 08:35 PM
dolphin2551
You Bet I WILL TEDG, If They Don't Solve The Problem!!!!! C6 AUTOMATIC'S BEWARE!!!
Old Jul 10, 2005 | 04:16 AM
Crush's Avatar
Crush
I am having the same issue, Is this a "problem"?? Can It be fixed??
Old Jul 10, 2005 | 05:34 PM
4CEE's Avatar
4CEE
Default Steering Noise
Seems like a rather rare problem, though dolphin has been squealing about it for a couple of months now. It’s a shame it hasn’t been reconciled. Here’s a couple related links:
http://forums.corvetteforum.com/show...e&forum_id=101
http://forums.corvetteforum.com/show...se&forum_id=74
Old Jul 10, 2005 | 05:56 PM
dolphin2551
WELL PROBLEM HAS BEEN SOMEWHAT RESOLVED GM TECH CAME IN AND HEARD THE PROBLEM AND ORDERED KERBECK TO CHANGE THE POWER STEERING PUMP GOT RID OF SOME OF THE NOISE THE REST SOMEWHAT STOPPED WHEN THEY REPLACED THE RACK HASN'T COMPLETELY STOPPED BUT IS MUCH BETTER THE PROBLEM IS GM TELLING SERVICE PEOPLE WHAT TO DO ON THE OTHER SIDE OF A COMPUTER NOT HEARING OR SEEING THE PROBLEM FIRST HAND!!!
Old Jul 10, 2005 | 06:18 PM
2005ArcticWhite's Avatar
2005ArcticWhite
St. Jude Donor '05 thru '11,'18,'20,'21,'24,'25, '26
Yes, I have that same noise coming from the front steering unit or area.
Also maybe like a rub on tire to fender?
Only when start up at a stand still.
Only for 2 seconds and its gone.
It does sound like a rumbling.
Mind is Auto
Z-51
Made in Jan 05
VIN appox 13,000
Old Jul 10, 2005 | 09:07 PM
Crush's Avatar
Crush
mine is also an A4, Z51
Old Aug 24, 2005 | 11:40 PM
Crush's Avatar
Crush
took my C6 to the local dealer yesterday for this problem. They couldnt make it happen there but they did find a bulletin. Here is what it reads:
"05 corvette low resonance vibration at idle when turning- kw left line pump right steering turn wheel #PIC3109 - (Aug 19, 2004)
Condition/Concern:
Some customers may state that there is a low resonance vibration feeling in the steering wheel when turning the wheels slightly in either the right ot left direction when in the stationary position at idle. The condition seems to apper on vehicles equipped with the 4L65E automatic transmission.
Recommendation/Instructions:
This is a normal characteristic of the vehicle and no repair attempts should be performed."
Document ID# 1546118
IMO this is totally unacceptable, looking for suggestions on what I should do next??
Old Aug 24, 2005 | 11:50 PM
2005ArcticWhite
Old Aug 24, 2005 | 11:54 PM
mss8022's Avatar
mss8022
I have the issue on my C6 A4...doesn't bug me...maybe it should.
Old Aug 24, 2005 | 11:55 PM
Guitarstar's Avatar
Guitarstar
I have 4000 Miles she's an automatic, no problems. I think I will keep her.
Who loves ya baby?
Old Aug 25, 2005 | 09:24 AM
peetoom's Avatar
peetoom
The rumble sounds like a slipping fan belt.
I Turned off the A/C on mine and the noise stopped.
Awful lot of spinning mass up there being driven by an oversized rubber belt.
Notice that belt driven superchargers use a cog toothed belt, and they even have a tendency to shear off the cogs.
Just a thought, may be a weak spring in the idler/tensioning pully.
Old Aug 25, 2005 | 09:34 AM
VET4LES's Avatar
VET4LES
Sounds normal to me, but take it to a different dealer. It is a lot of work for the power steering pump to turn the mass when not moving. I think the large tires make it worse.
To steering problem
Old Aug 25, 2005 | 09:43 AM
p-md's Avatar
p-md
This could be the SNS (steering noise syndrome) and it is GM's way of keeping the A4 on par with the M6 and its DBS (dead battery syndrome)
Old Aug 25, 2005 | 11:13 AM
prc6vette's Avatar
prc6vette
I have the same 'problem'.
It's infrequent, but I don't think GM should consider it 'normal'.
I was going to have the dealer look into, but I guess I'll save them the time.
It's kind of embarassing when it happens.
Old Aug 29, 2005 | 12:24 AM
Crush's Avatar
Crush
I know what ya mean when you say its embarassing
