steering problem
Old Aug 29, 2005 | 12:35 AM
bangbgC6's Avatar
bangbgC6
The only time I can recall feeling a vibration/unbalanced sensation in the steering was when my crank pulley bolt had loosened sufficiently to allow the crank pulley to have contact with the steering rack, amazingly enough the belt stayed on that time so the power steering never failed and the charging system was still functioning so no warnings on the DIC.
I was able to shut down immediately. Since it had happened only a week earlier I was keenly aware of any and all noises the car was making. It was definitely a rough feeling directly through the wheel.
Old Aug 29, 2005 | 01:28 AM
vetteship's Avatar
vetteship
Originally Posted by 2005ArcticWhite
normal characteristic
Yeah right, like the steering lock problem on the C5's.
Old Aug 29, 2005 | 01:45 AM
rga007's Avatar
rga007
I have the same noise (rumble and vibration) too...automatic and Z51. I figured it was a normal characteristic and it doesn't seem to affect performance. Sure would be nice if those people in Kentucky would explain the reason for the "normal characteristic" in their service bulletin PIC#3109. Sounds like the're hiding some design flaw.
Old Aug 29, 2005 | 02:49 AM
RX4WRK's Avatar
RX4WRK
Originally Posted by TYLERTONY
I've noticed the same problem as well lately..only 1300 miles and auto too...anyone else?
YES!!
I have posted this problem on other threads.
A4 Z51
A vicious growl...when cranking the steering...as the car begins to move...the grinding sound and then the vibration is telegraphed to the steering wheel...don't know if it is the rear end, trans, or brakes??
Old Aug 29, 2005 | 12:18 PM
dolphin2551's Avatar
dolphin2551
I notied that when I took the run-flats off and put toyo tires on alot of tire rubbing noises disappeared and the car ran smoother on the road! With what kerbeck did and i did my steering problem and noises are gone touch wood!! Thank you, Kerbeck for bringing a gm tech!!
Old Aug 29, 2005 | 08:24 PM
RX4WRK's Avatar
RX4WRK
Is this problem strictly isolated to the A4's?
Any m6's with this noise?
Old Aug 30, 2005 | 03:34 AM
shopdog's Avatar
shopdog
Yep, normal. Check the tach the next time it does it. You'll notice the engine is turning less than 600 RPM, because the torque converter, the PS pump, alternator, etc are loading the engine enough to prevent it from idling faster. Jazz the throttle enough to get it to about 800 RPM and there will be no noise.
The problem is that the pump can't make enough hydraulic hp to turn the wide front tires at a stop when the engine is turning less than 600 RPM. So you get cavitation groan. This is typical behavior for a hydraulic pump. You have to turn it faster than some minimum speed to allow it to meet demand.
In the Corvette at a stop, that minimum RPM is a bit more than 600. That's why the guys with the MN6s typically don't see it. Their engines idle faster because they aren't loaded by a tranny sitting in drive.
Old Aug 30, 2005 | 10:34 AM
VET4LES's Avatar
VET4LES
Old Aug 30, 2005 | 01:12 PM
prc6vette's Avatar
prc6vette
I have a 6-speed. I wonder if it would be a good idea to have the idle raised, say a hundred rpm, when I get a tune?
