Not really balanced - LS2
Old Jun 26, 2005 | 03:53 PM
Steve Germany's Avatar
Steve Germany
Default Not really balanced - LS2
As powerful and strong as she is the LS2 has an unbalanced sound (at least in mine). Does anyone else feel that the C6 should sound more evenly balanced? I don't really want a louded ehaust just a less lumpy - a little more F1. Anyone else feel the same?
Old Jun 26, 2005 | 04:01 PM
2005ArcticWhite's Avatar
2005ArcticWhite
St. Jude Donor '05 thru '11,'18,'20,'21,'24,'25, '26
My C-6 feels balance. At idle feels real balance. VIN appox. 13,000
Old Jun 26, 2005 | 04:02 PM
Corvette Junkie's Avatar
Corvette Junkie
Night Race Blue 427
From: Muncie, Indiana ...... Can I buy an amplifier on time ... I ani't got no money now but I'll pay you before I die
It has the sound of an American V8 and I love it.
Old Jun 26, 2005 | 04:05 PM
ilkhan's Avatar
ilkhan
maybe you should have bought an XLR...?
Old Jun 26, 2005 | 04:32 PM
ztheusa's Avatar
ztheusa
Veteran: National Guard
Sounds OK to me! Especially when screaming by the overpriced and gosh Porsches and Mercedes on the Autobahn.
Old Jun 26, 2005 | 04:49 PM
Datawiz's Avatar
Datawiz
CI-7-8-9-10 Veteran
Cruise-In IX AutoX Winner
St. Jude Donor '05 thru '11,'19,'22,'25
St. Jude/CI Name Tag Designer
Feels good to me. Much less refined than other cars, but it's supposed to be a big, brutal V8. That's the point!
Old Jun 26, 2005 | 05:01 PM
jazzlove's Avatar
jazzlove
From: San Antonio Texas - Any sufficiently advanced technology is indistinguishable from magic
Hmmm... I read all the comments... My baby sounds and feels very refined to me. When she's idling, when I wind her up, she sounds/feels VERY balanced. American V8? Yea, but to me, not like small blocks of the past, more like thoroughbred European cars of today....
Just my 2 cents.
Old Jun 26, 2005 | 05:53 PM
bcmarly's Avatar
bcmarly
What do you mean by unbalanced and lumpy. We may have a communication problem here. Lumpy typically means an uneven idle mostly associated with V8's that have an aggressive cam, or older carbutated models that need a carb adjustment.
The F1 sound you're looking for can only be had with smaller displacement engines, with 4 valves and a redline above 7000 rpm's. maybe you could expand a little on what you mean.
Old Jun 27, 2005 | 06:22 PM
Steve Germany
The feeling is not like a heavy cam - she feels like 2 cylinders are stronger than the rest of the 8. Perhaps mine is unusual... It is definately not a weak engine. It is just that there seems to be a surge in the 8 piston firing cycle. No one else feels this? I am a little sensitive to this kind of feeling since I have a long history of motorcyles.
Old Jun 27, 2005 | 06:41 PM
Lazerwolfe's Avatar
Lazerwolfe
From: I am Jack's out-dated Fight Club reference. MD
Beat me to it. Even if the LS2 could rev to 10 grand it wouldn't sound remotely F1.
Old Jun 27, 2005 | 07:15 PM
Karfever's Avatar
Karfever
My ZR1 had the sound of the F1 cars but that type of 'sound' has alot to do with valve train etc. I like the ol push rod V8!
Old Jun 27, 2005 | 08:42 PM
shopdog's Avatar
shopdog
Modern V8 engines use a dual plane crank, which, while it balances the primary couple of the engine, introduces a secondary couple. That, combined with a firing order designed to simplify tuned induction and exhaust systems, gives the V8 a characteristic "lope". This may be what you're feeling.
Old Jun 27, 2005 | 09:19 PM
David Lasic's Avatar
David Lasic
Default Never F1 Sound
Not very likely as most of the F1 sound I saw at Indy a few weeks ago was a lot of whining and moaning. Definitely European, and you can keep that. Forever.
Old Jun 27, 2005 | 09:33 PM
Big Lebowski's Avatar
Big Lebowski
I guess GM shouldn't ship them overseas on their side anymore...sure you can fit more of them in a container, but with this whole unbalanced engine thing, it hardly seems worth it.
Old Jun 27, 2005 | 09:39 PM
stanleyp's Avatar
stanleyp
It's an OHV, for pete's sakes. F1's run up to a gazzilion RPM. No way you can compare the two.
Old Jun 27, 2005 | 11:31 PM
christopher04z06's Avatar
christopher04z06
On a tangential note, Nascar V8's (old school OHV) often run higher piston speeds than F1 high RPM engines with a very short stroke Also, HP/Ib-motor, its really hard to beat the LS series V8 which spells performance if not "refinement".
Old Jun 28, 2005 | 12:31 AM
The Example's Avatar
The Example
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
All I know is the LS2 sounds a hell of a lot more refined than my LT1.
Old Jun 28, 2005 | 03:32 AM
Steve Germany
Thanks Shopdog,
Your explaination completly makes sence. Thanks for the effort!
To Not really balanced - LS2
