Transparent Top - Does it Do Anything?
Old Jun 29, 2005 | 08:40 PM
  #41
Lerxst2112's Avatar
Lerxst2112
Two advantages to the clear top nobody's mentioned so far...
1. It turns a gray sky blue. I'm not kidding, look up.
2. Two words: traffic helicopters. Upward visibility is a good thing.
If cost is no object, get both. I did (though cost certainly was not "no object" with me.) I use the clear one 80% of the time but when it gets over 85F have to switch to to the painted one or roast upon entering the car.
I note some people have complained about noise with the clear. Au contraire, (at least on my C5) the painted top is noisier with body flex than the transparent one.
Old Jun 29, 2005 | 08:54 PM
  #42
Datawiz's Avatar
Datawiz
CI-7-8-9-10 Veteran
Cruise-In IX AutoX Winner
St. Jude Donor '05 thru '11,'19,'22,'25
St. Jude/CI Name Tag Designer
Originally Posted by martman4
I live in southwest Fl and have the clear top. It may be a little bit warmer but I love the open feeling it gives the car. It does scratch so be real careful with it when stowing it in the rear. I love the clear top though.
Where in SW FL? Check into the sunshade from MidAmerica. I got one and it cuts the heat by 10 degrees.
http://www.madvet.com/shop?frame=7.163.6420
Old Jun 29, 2005 | 10:32 PM
  #43
LKicklight's Avatar
LKicklight
Default Lexan Top
Had an opportunity to swap my hardtop for the Lexan Top, easy choice, think the car looks a whole lot better, and fun to drive at night, summer time, top is off most of the time anyway.
kickback
Dallas, Ga.
Old Jun 29, 2005 | 10:46 PM
  #44
Force-1's Avatar
Force-1
St. Jude Donor '08 thru '24
I believe in the Beer Fairy
USAF (Retired) 1979-2001
Originally Posted by Gray Weasel
Get both in the Summer the heat with a glass top will kill you but it sure is nice in the winter and it gives the car a different look with each.....That is one option that I would not be with out ROCK ON
I don't agree the heat in the summer will kill you. I live in Albuquerque--5300' above sea level so sun is vicious. Yesterday my C6 sat outside all day at work in 95 degree weather with clear top in. car was not unbearably hot when I got in, and was nice and cool in a matter of minutes with A/C on and windows down to blow out hot air. My silver top is in the shed and will probably stay there unused.
Old Jun 29, 2005 | 10:55 PM
  #45
LS WON's Avatar
LS WON
Default I have a coupe with the painted top. I ordered both tops but it was on constraint
Since ownership personally I prefer a fixed roof as I find that I don't remove the top much at all and it heavy better handled by 2 people...This is a problem to me but I must say with the painted top you have more privacy. In any event I would have got both tops at the time if that option was not on constraint. I would think though that the clear see through top will eliminate some blind areas you can't see with the solid painted top brighten the interior up plus you can spot CHP helocopters and airplanes
Old Jun 29, 2005 | 11:10 PM
  #46
Zachman's Avatar
Zachman
My Victory Red C6 I think looks better with the painted top and in Houston with 100 degrees and 100% humidity it's a whole lot cooler. But I will probably use the transparent top this fall and winter.
Old Jun 30, 2005 | 05:38 AM
  #47
coolcat's Avatar
coolcat
I would NEVER own a C6 without the transparent top. The boring solid top gives the cockpit a "closed-in feeling". The clear top gives the interior an "open feeling".
Old Jun 30, 2005 | 09:12 AM
  #48
Scissors's Avatar
Scissors
☠☣☢ Semper Ebrius ☢☣☠
Cruise-In IV-V-VI-VII Veteran
St. Jude's Donor '06
Originally Posted by Noggles
I disagree, fully. The Z06 exhaust was acceptable, but the C5 stock exhaust was downright pathetic.
Still louder than the C6 exhaust.
Old Jun 30, 2005 | 09:34 AM
  #49
TRAYC7's Avatar
TRAYC7
NCM Ambassador
CI-3-4, 9 & 10 Car Show Winner
CI-3-4-5-6-7-8-9-10 Veteran
St. Jude Donor '04-'05-'06-'07-'08-'09-'10,'14, '16
St Jude Fedex Bowl Donor '09
I love mine....it adds a great constrast with Silver... I also know a guy here in town with a White C6 with a trans top and it looks great... so yours will be
Old Jun 30, 2005 | 09:46 AM
  #50
Crazy Cowboy's Avatar
Crazy Cowboy
Premium Supporting Vendor
From: www.EXOTICVETTE.com - FL Cruise-In VI, VII, & VIII
Cruise-In V Veteran
St. Jude's Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16
I love the clear top on my black car, like someone said earlier - you can't tell from the outside. Also, most people who have never been in the car (or a Vette) usually it's the first thing they notice "WOW! The top is clear!?!? Ooooo... it's cool looking!" is about what you usually hear. The roof ridge lines also look sweet.
Old Jun 30, 2005 | 10:40 AM
  #51
ProfMoriarty's Avatar
ProfMoriarty
Look great from the inside.
With the exception of black cars, nothing to write home about from the outside.
Old Jun 30, 2005 | 11:19 AM
  #52
corvettejimw's Avatar
corvettejimw
CI 4-5-6-7-8-9 Veteran
St. Jude Donor '08
I have a silver car and I ordered both tops when I bought it. I switch them out all the time...
Its the best way to go, you will never question it. Its like changing your shirt.....you can make it look different and if you want.......on a very hot day put the solid top in and enjoy a cool drive....or on a nice country road drive, put in the clear and enjoy the trees and blue sky over head and still stay cool.
Old Jun 30, 2005 | 02:39 PM
  #53
degaux's Avatar
degaux
DITTO!!! the only way to fly
Old Jun 30, 2005 | 05:29 PM
  #54
TommyV's Avatar
TommyV
St. Jude Donor '06-'07-'08-'09-'10-'11-'12, '16
Anyone tried tinting the top to reduce the heat? A friend tinted his moon roof on his RX8 and said it helped a lot.
Old Jun 30, 2005 | 05:45 PM
  #55
2vette2's Avatar
2vette2
Veteran: National Guard
St. Jude 15 Year Donor
St. Jude Donor '09-'25
Originally Posted by Dave@Kerbeck.com
IMHO, it opens up the interior. Maybe I'm not much for confined spaces, but that's how I feel with the painted top. I think the glass top makes the interior feel larger.
Old Jun 30, 2005 | 07:52 PM
  #56
JH's Avatar
JH
Both tops very useful. Winter top (translucent) and summer top (opaque).
Old Jun 30, 2005 | 08:29 PM
  #57
Mike2013's Avatar
Mike2013
St. Jude Donor '03-'26
I only have the transparent top on my C5. Took it off today and went for a drive. In Nashville today the high was 96. I was only gone an hour and came back looking like a crispy critter. I love my tranparent top.
  #58
V Vette's Avatar
V Vette
..makes you go balder, faster...
